maf problem - Mustang Evolution
Old 07-15-2014, 06:23 PM   #1
maf problem
Hello i got a 89 gt h/c/i car with 30# injectors 70mm tb. My problem is it idles from 1500-stalling it pops and jerks at any rpm when you dirve it. So its got a new tps and iac and idle has been reset many times tps is set good and computer has been reset many times. So i cleaned the maf with maf cleaner really good no change. untill i unplugged the maf it started right up and idle perfect revs fine no poping idles down slow though. so do any of you guys think i need a new maf. btw the maf is a 75mm 30# injector maf.
Wanted to see what you guys think or how to make sure its that before spending 230$
Thanks
slow89gt is offline   Reply With Quote
Old 07-16-2014, 03:31 PM   #2
Hellish Horse's Avatar
So after you cleaned your MAF Sensor were the wires a Bright Shiny Silver ? Is the wire between the 2 Thicker wires still connected ? ( Similar to the wires in a Light Bulb or Fuse)
I'm not real sure about the Spray MAF Cleaner as I always use Paint Thinner & Rubbing Alcohol to clean mine. But the paint thinner leaves a residue on the wires so you have to use a Q-Tip & Alcohol to clean the residue off afterwards. If the wires are connected & it all looks clean you might want to try wiping it off with a Q-Tip & Alcohol. Can't hurt & could save you some bucks.
$230 seems like a lot for a Sensor....or are you talking about buying the housing & all ?
it sure sounds like it's a MAF Sensor problem though.
Hellish Horse is offline   Reply With Quote
Old 07-16-2014, 04:47 PM   #3
Frenchstang's Avatar
Did u do a tune by a professional ???
Frenchstang is offline   Reply With Quote
Old 07-16-2014, 06:38 PM   #4
yes i was told it was tuned. And after cleaning one wire looks good and one is brown on one side like a blown fuse.
Old 07-16-2014, 07:03 PM   #5
I'm thinking it's not clean enough or that wire is burnt or something. I'm 99 % sure that's your problem. You may have to buy a new one if it doesn't clean up. I'd go buy a small bottle of paint thinner @ Walmart for $2.50 & clean it that way before I invested in a New MAF. Just fill up some kind of small cap with thinner & let the wires soak over night in it. Paint Thinner wont melt plastic so no worries. Next day clean it off gently with Alcohol on a Q-Tip. Then put it in & try it out. If it still acts up...Then Replace it. I'm pretty sure it should clean up though as mine was real bad & looked liked new after I did this.
Old 07-16-2014, 07:03 PM   #6
If you were only "told it was tuned" with no receipt then I would assume it wasn't if I were you. Not to mention nobody with a tune is going to put a #30 MAF in there. Or if you did that would be why it is idling crappy. If it really was tuned then the tuner would have calibrated the fuel tables in the computer for whatever MAF was in there.
Need more details but if its an HCI car and not performing well a bad or stock tune is usually the first culprit.
Old 07-16-2014, 08:10 PM   #7
its got a diablo sport chip dyno tuned.
Old 07-17-2014, 08:30 AM   #8
doesn't mean it was tuned properly. Dude could have had some mail order tune on there and like I said if you put in a different MAF after the fact tuned for #30s then that could have screwed it all up.
Old 07-17-2014, 06:13 PM   #9
maf indeed fixed it a buddy had one so i borrowed it and its pulling like a boss and idles prefect. thanks for the comments. guys
Old 07-17-2014, 09:24 PM   #10
Good to hear you solved the problem. Now "Drive It Like You Stole It", Heel to the steel & pedal to the Metal !!!
Old 07-17-2014, 10:01 PM   #11
thanks. i will
Please help!!! :( plzzzzz tps / maf problem. arphell 2005-2010 V6 Mustang 3 01-16-2013 07:30 AM
MAF-sive problem. daddydigest 1996-2004 Mustang GT 2 09-21-2012 09:52 AM
95 5.0 MAF upgrade to a 80mm 2000 4.6 MAF chatanaka36 1979-1995 Mustang GT 3 07-03-2012 08:57 PM
Cleaned tb/plunum/maf now have problem 02PONY 1996-2004 Mustang GT 5 02-26-2012 08:33 PM
04:31 AM
