electrical TROLLS - Mustang Evolution
Old 07-16-2014, 06:27 PM   #1
electrical TROLLS
Hey guys im having a big electrical problem. Slowly my electronics started failing. First my tachometer doesnt light at night. As in when i switch in the lights, my tach doesnt light up, nor my idle brake lights. But highbeam indicator lights up. Then my directional lights and braking lights stopped working. So now no function in rear lights. But my headlights still work. Then i checked fuses the ones i managed to pull out by hand were ok, but then i started driving and it started smoking under my dash whenever i drive it smells like burnt plastic. Help me please?
El Peludo is offline   Reply With Quote
Old 07-16-2014, 08:02 PM   #2
Hellish Horse's Avatar
Sounds like you have a short under your dash that's grounding out to me. I feel for you as that can be a real PITA to find.
Hellish Horse is offline   Reply With Quote
Old 07-17-2014, 12:52 AM   #3
racks2relax's Avatar
Same problem, make sure you pull up a diagram telling you how many amps per fuse. You could be running a 15 amp fuse on a 10 amp and can easily cause a fire. Since you already had the smoke signal you might have burned the wires.
Sent from my SM-N900P using Mustang Evolution mobile app
racks2relax is offline   Reply With Quote
Old 07-17-2014, 01:02 AM   #4
After the smoke happened to me, I checked the fuses and turned out to be #4. Which leads to running taillights, turn signals, dash lights, and Cat Lights (headlight in side and out side smaller lights). Your headlights (middle part) should still operate, and when you hit the breaks the break lights should too. You have a short. Easiest way to fix it is take the dash apart and find the burned wires. I had a couple burnt together, and they led to my Light/defroster switch. Good luck!
Old 07-17-2014, 01:05 AM   #5
Look for these signs!
ID:	161638   Click image for larger version
mechanical or electrical gauges? tedness Pre-2005 V6 Mustang 1 03-26-2005 12:44 PM
Trolls car and car audio Troll The Bar 26 03-23-2004 01:18 AM
04:25 AM
