Please watch - Mustang Evolution
Old 07-16-2014, 08:58 PM   #1
kyle_rivas's Avatar
Please watch
My 89 gt is getting hot very fast watch the video and let me know what you think? Please I have a new thermostat flushed the radiator new antifreeze everything I can think of idk what else please and thanks 5.0 mustang: 5.0 mustang - YouTube
galaxy s4
kyle_rivas is offline   Reply With Quote
Old 07-16-2014, 09:12 PM   #2
Muller's Avatar
Stupid question but did you put the thermoset in the right way?
Muller is offline   Reply With Quote
Old 07-16-2014, 09:34 PM   #3
kyle_rivas's Avatar
Lol its all good I was told that already so I took it off and made sure everything is good but its so frustrating knowing I cant go far or my engine will shoot water everywhere
galaxy s4
Old 07-16-2014, 09:46 PM   #4
Muller's Avatar
Is the water pump leaking out if the tattle tale?
Old 07-16-2014, 10:05 PM   #5
kyle_rivas's Avatar
Brand new water pump no leaks
galaxy s4
Old 07-18-2014, 06:49 PM   #6
Hellish Horse's Avatar
Try replacing your Coolant Temperature Sending Unit Sensor. Easy to replace. I bought mine on Ebay for $7.00.
Hellish Horse is offline   Reply With Quote
Old 07-18-2014, 06:51 PM   #7
Could be a Bad Radiator Cap also.
Old 07-18-2014, 10:53 PM   #8
Did you burp the system?
Old 07-19-2014, 12:38 AM   #9
kyle_rivas's Avatar
What do you mean by burp?
galaxy s4
---------- Post added at 06:38 AM ---------- Previous post was at 06:38 AM ----------
galaxy s4
Old 07-19-2014, 12:48 AM   #10
Tyoung68's Avatar
galaxy s4
galaxy s4
Air can get trapped in the system run the engine with the cap off and see if any air comes out
Old 07-19-2014, 02:20 AM   #11
kyle_rivas's Avatar
I did that before when I started it i left it open and little bubbles started coming up
galaxy s4
Old 07-19-2014, 05:13 AM   #12
Liebert91stang's Avatar
Was it doing this before you replace the water pump?
Liebert91stang is offline   Reply With Quote
Old 07-19-2014, 08:32 AM   #13
Tyoung68's Avatar
galaxy s4
Did you let it go till it stopped?
Old 07-19-2014, 10:40 AM   #14
kyle_rivas's Avatar
No when when I got the water pump my hole motor was apart so everything was fresh and I didn't check it at that time
galaxy s4
Old 07-19-2014, 11:43 AM   #15
Semerollin's Avatar
Replace the cap I bet that is your problem.
Semerollin is offline   Reply With Quote
Old 07-19-2014, 12:20 PM   #16
kyle_rivas's Avatar
Its all old and rusty and thanks I would of never knew
galaxy s4
Old 07-19-2014, 12:31 PM   #17
really? My cap apparently doesn't hold enough pressure and my car gets pretty toasty under the hood. Car does not over heat but gets hotter then it should in my opinion. Maybe the culprit really is the cap haha I will pick up a new one as well although if it was your cap I think you would be down on coolant.
TurboCobra is offline   Reply With Quote
Old 07-19-2014, 12:35 PM   #18
sorry. Just watched the video and realised your car is puking everywhere.
I did notice on you tube you have another video of your car from the 15th that was uploaded and it seems to be running fine. Did anything change since that video was recorded? did you do any other work to the car?
Old 07-19-2014, 04:24 PM   #19
kyle_rivas's Avatar
No the car is fine I drive it all the time its when I drive it for a wile it gets super hot and water shoots out that part yhe cars fine its just super hot when I drive it its ridiculous it will melt plastic in top of my manifold even my cold air intake gets supet hot due to the engine?
galaxy s4
Old 07-19-2014, 05:50 PM   #20
Water pump correct rotation?do you have electric fan?the water comming out in the video looks very discolored and rusty.tou flush it good?
Old 07-19-2014, 06:30 PM   #21
kyle_rivas's Avatar
Ya I flushed it really good new antifreeze fresh water I have the stock fan but it works dam good what do you mean by correct rotation? After I installed everything and got my motor back and running about a week later I went houston to galveston a really long drive no over heating problems what so ever its just started do it now if I go on ling trips
galaxy s4
Old 07-20-2014, 08:24 AM   #22
Semerollin's Avatar
Your not getting water in the oil are you. A blown head gasket can cause air to go into your water jackets and cause overheating issues. Have you changed the cap yet?
Old 07-22-2014, 12:03 AM   #23
Bradley_ruble's Avatar
My 95 is doing the same thing. And I can't figure it out
Bradley_ruble is offline   Reply With Quote
Old 07-22-2014, 01:59 PM   #24
Infantry09's Avatar
Question... Is your new water pump flowing in the right direction?
Infantry09 is offline   Reply With Quote
Old 07-22-2014, 03:05 PM   #25
kyle_rivas's Avatar
Hmm how would I know if it is or not?
galaxy s4
Old 07-22-2014, 03:17 PM   #26
Infantry09's Avatar
U said in a previous post that you replaced the water pump. You might have gotten one with the wrong rotation.. One way u might be able to tell is start your car wait for it to warm up, then grab the lower radiator hose and see if it's hot or not.
Old 07-22-2014, 03:37 PM   #27
kyle_rivas's Avatar
I replaced it when I had my motor off brand new pump with brand new hoses and I will try that
galaxy s4
Old 07-22-2014, 04:07 PM   #28
Tyoung68's Avatar
Or if you routed the belt wrong
Old 07-22-2014, 05:42 PM   #29
kyle_rivas's Avatar
If it was wrong wouldn't something go wrong?
galaxy s4
Old 07-24-2014, 02:35 PM   #30
Infantry09's Avatar
Did u figure out the problem with your water pump?
Old 07-24-2014, 02:54 PM   #31
kyle_rivas's Avatar
I think my water pump is fine but I haven't drove it in a while I just put a new intake and manifold on
galaxy s4
Old 07-24-2014, 03:36 PM   #32
Tyoung68's Avatar
galaxy s4
Did you check to see if the gaskets were right? Or did you put them on backwards?
Old 07-24-2014, 04:58 PM   #33
kyle_rivas's Avatar
How do u know if they were backwards?
galaxy s4
Old 07-24-2014, 05:30 PM   #34
Tyoung68's Avatar
galaxy s4
Well i have no idea if it can be but you would have to take it apart to see. I don't even know if you have coolant passages into your intake?
Old 07-24-2014, 05:32 PM   #35
kyle_rivas's Avatar
Here's the intake im using
galaxy s4
Please watch and comment Mustangman705 1996-2004 Mustang GT 26 09-28-2013 12:21 AM
Please watch and think.........seriously. DDTCM Pictures and Videos 15 02-07-2013 09:54 AM
Why we dont street race, please watch 2Greeny7 Pictures and Videos 21 06-13-2012 09:40 AM
Must watch Ron Paul Video. Watch it. Now. Brent The Bar 1 04-28-2008 05:18 PM
12:20 PM
