How do install a shift light? - Mustang Evolution
Old 07-16-2014, 09:54 PM   #1
94gtconvert's Avatar
Hey, just orderd a cheap shift light for my 94 gt. It has 3 wires, 12 volt switched power, ground witch I can figure out, but the third wire is a signal wire. Where do I splice this wire to? Also any mounting location ideas? I was thinking In the heat/ac vent
94gtconvert is offline   Reply With Quote
Old 07-16-2014, 10:06 PM   #2
kyle_rivas's Avatar
Right there on the right side of the dash
galaxy s4
kyle_rivas is offline   Reply With Quote
Old 07-20-2014, 08:40 AM   #3
galaxy s4
Not shure what you mean
Old 07-22-2014, 01:33 AM   #4
racks2relax's Avatar
Got a picture of it?
Sent from my SM-N900P using Mustang Evolution mobile app
racks2relax is offline   Reply With Quote
Old 07-22-2014, 09:26 PM   #5
Figured it out, there's three wires as I stated one is ground BLACK easy enough, one is 12v RED switched ignition, and one is GREEN witch is the the signal. I found with the 5.0 it's easyiest to run a wire out under the hood to the coil next to the distributor, and splice in to the yellow wire or left wire on the 2 prong harness that plugs into the lower part of the coil, this is the negative. The shift light is a cheapo eBay LED adjustable one, and works exelent for the $19 I played for it. I also didnt glue or screw any holes in my dash, I just bent the bracket and clipped it onto the center console near the pedals where my legs won't hit it and aimed it up at my face. I'm contemplating dissecting the board out of it and hooking up a brighter auto meter mini or raptor tack light because the eBay one is not all that bright when the sun hits it, but at night it's obnoxious.
Old 07-23-2014, 03:43 PM   #6
silverstone's Avatar
Take a picture where to connected it.
silverstone is offline   Reply With Quote
Old 07-23-2014, 04:48 PM   #7
Here's some pics of the wire and where I mounted it. Its actually a white wire I'll put arrows to it in the pic. Also I KNOW ITS A AUTOMATIC I use the b&m ratchet shifter at the strip and it works exelent, so I figured I'd install a shift light so i can really wind her out without red lineing.
ID:	162101   Click image for larger version
ID:	162103   Click image for larger version
Old 07-23-2014, 04:59 PM   #8
Nice shifter! I didn't know you could change the ugly handle part on these. I might get one now. Looks really clean
Old 07-23-2014, 05:05 PM   #9
Thanks, it's available on American muscle.com, it's made by b&m. I had my factory AODE spiced up with a shift kit and a stalled converter when it took a poop. Now I can controll every gear with this shifter SAFELY without missing second or going into reverse by accident because the factory shifter can do that if you just touch the brake. I also changed the knob because the T handle it came with was so tall my finger couldent pick up the lock witout putting my Palm all aquard.
Mustang sport shift (shift at 3000 rpm's ?) Charlesph55 2011-2014 V6 Mustang 5 07-24-2014 09:58 AM
Raptor Shift Light Install Big Q 2011-2014 Mustang GT 5 06-09-2014 06:03 PM
shift kit install 3stangs 1979-1995 Mustang GT 0 06-27-2013 04:47 PM
Annoying shift issue in Sport Shift mode... alludc 2011-2014 V6 Mustang 9 02-08-2013 02:20 AM
Econo Shift/Skip Shift Rant michael81 2011-2014 Mustang GT 17 01-30-2012 06:52 PM
08:28 AM
