No difference In power after half way throttle - Mustang Evolution
Old 07-19-2014, 03:40 PM   #1
Rob94gt's Avatar
Hey guys. I have a question. My 94 gt runs pretty good and strong.
My question is, it has good pickup when I push the gas pedal untill half throttle. From halfway to wide open throttle it doesn't make much difference.
It runs the strongest at half throttle if I go anymore it just doesn't seem like it does anything idk if that is normal or not.
Has anybody else had this problem?
I've checked the tps with a voltmeter and it was reading good from no throttle to wot.
Mainly stock 302 with gt40 p heads and a explorer intake with a 1 inch spacer,cold air intake, shorty headers and a msd 6al ignition box. Any help would greatly be appreciated!!!
Rob94gt is offline   Reply With Quote
Old 07-19-2014, 09:36 PM   #2
Frenchstang's Avatar
Same thing to me ! I cleaned up MAF and probleme fixed ! Try it if did nt do it already !
Dany
Frenchstang is offline   Reply With Quote
Old 07-19-2014, 09:45 PM   #3
Rob94gt's Avatar
Ok. It's been prolly 2 years since I have cleaned it. But I deff will try that.
Thanks for the advice.!
Old 07-19-2014, 11:30 PM   #4
JOberlander's Avatar
Mine was doing that and cleaning out the air intake and putting in a new filter solved it. Note that this is on a V6. The V8 is a lot less forgiving of showing problems due to dirt and restricted intake than the V6 is. I'd recommend checking everything at half the interval Ford recommends.
Note - lag/loss of power at high throttle usually points to restriction in airflow in modern fuel injected engines.
JOberlander is offline   Reply With Quote
Old 07-20-2014, 10:01 AM   #5
When is the last time you did your fuel filter?
Old 07-20-2014, 01:40 PM   #6
Rob94gt's Avatar
It's been bout a year and a half since I changed my fuel filter. But any ideas help. I'll change it since it's prolly due anyways.
And I have a cold air intake but I'll check everything to do with the intake. To make sure it ain't clogged or dirty.
Old 07-20-2014, 01:41 PM   #7
Rob94gt's Avatar
When I rev the motor under the hood in quick Burst I can hear the intake sucking air real good
1inch difference after crash Ahmed ali khan 1996-2004 Mustang GT 9 11-11-2012 06:43 AM
can't push gas pedal in more than half way help 95 gt guy 1979-1995 Mustang GT 43 07-02-2011 11:31 PM
Half Human, Half Tree Brent Pictures and Videos 11 11-26-2007 10:01 AM
Half Length Denscharger sctalbott Pre-2005 V6 Mustang 10 12-04-2003 10:48 AM
01:30 PM
