Shifter shaking problem - Mustang Evolution
Old 07-22-2014, 03:55 PM   #1
SkylerTallman_'s Avatar
Hey guys, the other day I noticed at high speeds and even sometimes at low speeds, my shifter will shake. At low speeds it isn't bad at all but at high speed it shakes so crazy it scares me. I took a look at all the bolts and everything is bolted in properly and tight. Would that be my driveshaft being unbalanced or what could It be? Any suggestions. It's a 94 5.0. Should I just give in and buy a aluminum driveshaft?
SkylerTallman_ is offline   Reply With Quote
Old 07-22-2014, 04:25 PM   #2
It sounds like a bad U-joint in your driveshaft
zachm1011 is offline   Reply With Quote
Old 07-22-2014, 09:00 PM   #3
That or the nuts attaching your trans mount to the crossmember backed out. Check the U-joints and check your trans mount. Also check the engine mounts. At this age, if your rubber mounts are original consider them shot.
Old 07-22-2014, 09:13 PM   #4
Ordered a new u joint a few min ago. Thanks guys
Old 07-23-2014, 12:05 PM   #5
Well did you actually verify that was the problem?
Old 07-23-2014, 12:08 PM   #6
smurf stang's Avatar
Did you get under the car and check the crossmember and tranny mounts.
2016 VW GTI 2.0 Turbo
Old 07-23-2014, 12:47 PM   #7
Yes it is the u joint.
Old 07-23-2014, 12:52 PM   #8
I'm going to have to redo my exhaust doing it to because the last owner didn't give enough room for the driveshaft to come out.
Old 07-23-2014, 04:10 PM   #9
You don't have to redo anything, just drop the H pipe out.
Old 07-24-2014, 06:29 PM   #10
I had same thing happen to my 89 gt it was driveshaft not ballenced the weight came off it cost 50 bucks to get it reballenced
Sent from my SCH-I200 using Mustang Evolution mobile app
ermer03 is offline   Reply With Quote
Shaking problem now. SkylerTallman_ General Mustang Discussion 18 06-24-2014 07:36 PM
Shaking problem 813floridaracin Pre-2005 V6 Mustang 12 07-14-2013 05:45 PM
shaking 5.0homustang 1979-1995 Mustang GT 5 04-10-2006 09:28 PM
shaking problem at 60mph timekiller Pre-2005 V6 Mustang 6 03-19-2006 12:48 PM
Shaking above 55mph any ideas? SpectorV Pre-2005 V6 Mustang 11 07-20-2004 09:44 AM
03:53 PM
