Cobra manifold bolts - Mustang Evolution
Old 07-24-2014, 08:18 PM   #1
kyle_rivas's Avatar
Ok I recently bought a cobra upper and lower and when I get to the last part as in finishing the things it needs 6 bolts on top the short ones fit just fine the outer bolts fit the ones from the stock 5.0 manifold and it the 2 really long bolts in the middle by the cobra sign I cannot find them anywhere so I went to tractor supply and bought some long bolts all thread that everyone said will work and I got home meauserd them cut them put them on torked the first one no problem torked the second one the dam thing breaks off so now I have to take everything back off and start over can someone please help me out where to find some bolts if you have put the cobra upper and lower on before what did you do apparently the bolts like to break in there thanks.
galaxy s4
kyle_rivas is offline   Reply With Quote
Old 07-25-2014, 08:59 AM   #2
ALMOST STOCK's Avatar
What are you torqueing them too factory specs are only 12-18 Lb Ft of torque?
ALMOST STOCK is offline   Reply With Quote
Old 07-25-2014, 11:05 AM   #3
smurf stang's Avatar
The bolts are 5/16 18 x 7(I think it has been a while) but you can source these locally at your local supply house.
If you go to fordparts.com and use the part #M-6002-A50 it should come up as GT40 bolts.
2016 VW GTI 2.0 Turbo
Old 07-25-2014, 12:23 PM   #4
kyle_rivas's Avatar
Thanks and yes I was torqueing them to 18 lbs
galaxy s4
Old 07-25-2014, 01:21 PM   #5
kyle_rivas's Avatar
I cannot order them it wont let me and the bolt is a little less then 7 1/2
galaxy s4
Old 07-25-2014, 01:25 PM   #6
I still have the long bolts that came with the M-6002-A50 (GT40 Manifold Bolt Kit) and just went out and measured the length of the long bolts. They measure 6 Inches in total length.Thread pitch is as stated above 5/16-18
The GT40 Manifold Bolts kits consists of :
4 corner bolts are 5/16 x 1 5/8 and the 2 middle bolts are 5/16 x 6
Size and Thread pitch 5/16-18 in.
Old 07-25-2014, 01:28 PM   #7
galaxy s4
The bolt is to long you bottomed out before it ever got tight enough to torque it properly.
Old 07-25-2014, 02:37 PM   #8
As always Almost Stock to the rescue. I am pretty sure he has every picture ever posted about a foxbody.
Old 07-25-2014, 04:03 PM   #9
kyle_rivas's Avatar
Good information but I meauserd the bolt till it got tight with my fingers and then I tightend it and I dont think the middle bolts are size 6 because the other bolts are size 6 and dont fit inside the the middle
galaxy s4
Old 07-25-2014, 06:38 PM   #10
Hellish Horse's Avatar
Just Google "Nuts & Bolts" & stores in your area should pop up. Look for a Supply House & they will have what you need. In my area we have a place called "Copperstate Nut & Bolt Supply".
Buy Grade 8 & they wont break so easy.
Hellish Horse is offline   Reply With Quote
Old 07-25-2014, 06:41 PM   #11
You could always go to the junkyard & take the bolts off an Explorer or Mountaineer.
Old 07-25-2014, 07:07 PM   #12
kyle_rivas's Avatar
I got it guys thanks a lot
galaxy s4
Old 07-25-2014, 08:10 PM   #13
So how did you solve your dilema?
And remember that supply house are way better than HD or Lowes.
Old 07-25-2014, 08:26 PM   #14
kyle_rivas's Avatar
It was very helpful lol
galaxy s4
Old 07-25-2014, 08:40 PM   #15
And find that they are 6 inches in length ...
Old 07-25-2014, 08:49 PM   #16
kyle_rivas's Avatar
Ya lol I got it running but somethings not right...
galaxy s4
Old 07-25-2014, 08:59 PM   #17
kyle_rivas's Avatar
Well **** what does this look like??? 😂 do you like my oil color nice and creamy 😭😭😭😭 im actually really mad because I dont have the money to fix any of this I guess my mustang will just sit and rott 😢
galaxy s4
Old 07-26-2014, 01:03 PM   #18
This could be your problem, if the rubber hose is hooked up to a coolant hose and not a vacuum hose then your sucking coolant into the intake and more than likely the reason your seeing that creamy oil.
Old 07-26-2014, 01:28 PM   #19
kyle_rivas's Avatar
Yes all the water and coolent is coming out of the exhaust
galaxy s4
Old 07-26-2014, 02:11 PM   #20
You might want to check and see how you have the hoses ran then!
bolts bolts bolts! bcosta56 1979-1995 Mustang GT 8 10-10-2012 03:08 PM
Exhaust manifold flange bolts jwhayne0001 1979-1995 Mustang GT 14 12-30-2011 05:49 AM
broken lower manifold bolts shustwit Pre-2005 V6 Mustang 8 06-29-2011 12:02 PM
lower intake manifold corner bolts?? desperate for help!!!! Pascullon Pre-2005 V6 Mustang 0 02-18-2011 12:00 PM
Stage 8 bolts, but no bracket bolts? CreationNation 1979-1995 Mustang GT 1 04-13-2009 10:00 AM
11:00 AM
