95 5.0 going on3 turbo DIY intercooler - Mustang Evolution
Old 07-24-2014, 10:41 PM   #1
Region: Nevada
Okay so I'm doing a piece together turbo kit and am looking to do a universal intercooler kit and am looking for some info based on which one you would buy based on the pics I post, the reason for this is to save money to have for buying my fuel system, not sure which kit will have all the bends that I need! Please help
Name:	ImageUploadedByMustang Evolution1406263211.747781.jpg
ID:	162203Click image for larger version
Name:	ImageUploadedByMustang Evolution1406263220.366908.jpg
ID:	162204Click image for larger version
Name:	ImageUploadedByMustang Evolution1406263237.591117.jpg
ID:	162205Click image for larger version
Name:	ImageUploadedByMustang Evolution1406263268.550711.jpg
flatstanley1 is offline   Reply With Quote
Old 07-25-2014, 10:43 AM   #2
smurf stang's Avatar
I know you wanna save money but none of those intercoolers are for a mustang.
These guys are cheap and decent
cxracing.com: Ford
2016 VW GTI 2.0 Turbo
Old 07-25-2014, 11:00 AM   #3
Region: Nevada
The one at the end was from cxracing? It said mustang (universal)?
Old 07-25-2014, 11:02 AM   #4
Region: Nevada
That won't matter that it is for a supercharger and I'm going turbo? I don't think it will just wondering
Old 07-25-2014, 11:07 AM   #5
What will matter is the tubing. You want the correct set of tubing with the correct bends and the correct routing. If not you will have a whole set of useless pipes.
Call them they got tons of stuff.
Old 07-25-2014, 11:09 AM   #6
Region: Nevada
Okay thanx for the info!
Old 07-27-2014, 08:53 PM   #7
Piecing it together might not be the best idea, they go new for $1600 shipped on LRS I doubt you'll be able to piece one together for less than that or if you do it'll only be a few $hundred.
Old 07-27-2014, 08:58 PM   #8
Region: Nevada
I got the hotside for $325, have to peice it together
Old 07-28-2014, 05:40 AM   #9
Then just get the CX racing intercooler kit and modify it as needed to fit in your car. Might need to cut and weld a few things or just do couplers but it shouldn't be too much to route the tubing from the turbo to the intercooler. For a turbo... honestly there are really good reviews out now on the On3 67mm ball bearing turbo. They're made in the same plant that the Master Power turbos were in Brazil.
Old 07-28-2014, 02:16 PM   #10
Region: Nevada
I was reccomended an on3 lol that's what I plan on buying, and are you referring to a universal intercooler kit or the 89-93 mustang kit cause those are $300 difference in price! I fell the universal would work but what size
Old 07-29-2014, 05:59 AM   #11
Ok so I'm confused now. You already have the On3 kit hotside then? Honestly you might just want to call Chad at On3Performance and see if he'll sell you just the coldside. Or re-sell your hotside and just buy the whole kit. I've been through trying to piece things together on all different aspects of these cars, you'll go through more asspain and likely spend more money than if you just bought the complete kit.
Old 07-29-2014, 11:25 AM   #12
Region: Nevada
Yeah I have a boost brothers hot side
Old 07-29-2014, 01:01 PM   #13
Call them like I said....human to human like they did in the old days.
Old 07-29-2014, 08:08 PM   #14
I'd sell the hotside and just buy the whole On3 kit. As I said, less asspain and you will have a complete bolt in kit.
Old 07-30-2014, 01:32 AM   #15
natestang07's Avatar
http://www.cxracing.com/mm5/merchant...ory_Code=ICKMT
What else would you need besides the obvious head unit?
05 Gt Premium Performance White
Old 07-30-2014, 09:33 AM   #16
Region: Nevada
It's a 94 and injectors pump maf turbo
Old 07-30-2014, 09:55 AM   #17
Also will want to do the trans as the T-5 will be on borrowed time at that level. Rear upgrade is always a good idea if one plans on anything besides street radials and then there is suspension, chassis stiffening and the tune also. And if you plan on running on the track you might as well do all the track safety stuff now since a turbo 5.0 should be able to break into the 11s no problem.
Old 07-30-2014, 10:00 AM   #18
Region: Nevada
True true was thinking of picking up a 3550?
Old 07-30-2014, 10:56 AM   #19
I had one, I hated it. It shifts like a box of rocks and you still need to upgrade the 10 spline input if you want to push much past 500hp which you'd need a built motor/aftermarket block for anyway. My recommendation is an Astro A5. Its a T-5 on roids and will take 600+ easy.
Old 07-30-2014, 11:29 AM   #20
Region: Nevada
How much are they? And aren't they just the internals or an actual trans?
Old 07-30-2014, 12:20 PM   #21
Astroperformance.com - Your Manual Drivetrain Specialist
They're the best trans you can put in the car pretty much. Half the weight of a Magnum, will hold a ton of power and, being a T-5, is the smoothest shifting transmission you can get in a Mustang. Only downside is no gear between 4th and OD like a 6 speed.
They might look expensive, but you aren't going to put a new trans in the car for less $$. Not something that will safely hold 400-500hp anyway.
Old 07-30-2014, 12:50 PM   #22
Region: Nevada
So your reccomending a tko 600?
Old 07-30-2014, 12:57 PM   #23
I have a TKO and my boy has a Astro T5 built by Promotion and his is like butter and my trans is a little notchy and tough shifting passed 6k. If my hadn't come with one and I didn't rebuild it (half assed of course) with the upgrade carbon fiber and some bronze I would have bought a Astro any day of the week. Plus his car is a 363 single turbo pushing 700 and something to the wheels.
Old 07-30-2014, 03:25 PM   #24
Region: Nevada
Okay so the link they sent me showed a tko600 where is the astro rebuild stuff? Or is it a full trans?
Old 07-30-2014, 03:32 PM   #25
Region: Nevada
Is g force any good?
Old 07-30-2014, 05:07 PM   #26
No, the link I sent you was to the Astro home page. They are just advertising the 600. It sucks. There is a browse function on the top left of the website...
No, they are a wannabe Astro. Some ppl will claim that they are the same gearsets, they aren't. Anyone who has seen the G Force and Astro gears next to each other can clearly pick out which is which. Astro is physically much bigger.
Old 07-30-2014, 05:09 PM   #27
Region: Nevada
Okay so it looks like $2300 for the astro set?
Old 07-30-2014, 05:12 PM   #28
$2800 for the best one. You get a $300 refund if you ship them your core though. Shipping using their labels is $75. There is an option upon checkout to include this service. Being a T-5 externally, it is a direct bolt in and will work with all your parts. Although you would want to upgrade to a top end organic clutch or ceramic puck clutch or even a twin disc if you are planning on 400-500rwhp.
Not sure what else is done to the car but you will also need to make sure you have the fuel to support it, the suspension/tires, the chassis stiffening and a spot on tune once done. Also will probably want a good ignition box to keep the spark from getting blown out when you come into boost.
Old 07-30-2014, 05:17 PM   #29
Mo money mo money mo money
Old 07-30-2014, 05:23 PM   #30
This is why I will finance a Coyote before I build another Mustang up.
Old 07-30-2014, 08:19 PM   #31
Region: Nevada
That makes a lot of sense lol what about going auto? What are your recommendations In that area? I'm hoping for 460hp and 500 ft lbs so nothing to retarded power wise, but 3,000 is a little steep for a trans plus turbos love auto trans?
Old 07-30-2014, 08:21 PM   #32
Region: Nevada
I was told that a c4 will hate daily driving with boost?
Old 07-30-2014, 08:32 PM   #33
Swap your car to AODE and get an AODE that is rebuilt with 4R guts. On a budget, pick up a low mileage 4R70w from a wrecker (from a 98-up V6, the V8 versions have the modular bolt pattern but the V6 shares the bolt pattern with the old 5.0) and control it with a Baumann controller or a full manual valve body. You'd have to do a MVB with a C4 as well. You are going to pay $300-$500 for a good 4R, then another $500 for the controller and $600-$1k for a good converter. That is before any of the auto swap goodies, figure another $200-$300 for the right yoke, shifter any crossmember mods etc... This is also not factoring in any labor.
$2800 for a built 5 speed starting to sound reasonable yet?
Moral of the story is, 500hp and cheap are not in the same sentence. Not if you want the car to be any sort of reliable or be a DD. I'm not trying to be an ***, but just trying to illustrate how quick it adds up. Figure $1600 for the turbo, $3k for the trans shipped, another $500 for fuel and then if the chassis/suspension is stock you'll need another $1500-$3k for that as well depending on what you have. Finally $600 for the dyno tune. And then you have to be prepared to pull/replace stuff if it lets go at that level.
Again, not trying to be an ***, but a lot of ppl start buying stuff only to stop halfway because they had 0 idea how much extra **** was needed and how much they were going to get into it for.
Old 07-30-2014, 08:38 PM   #34
Region: Nevada
That's what I'm looking for so thank you, I've seen a lot about the aide to 4r internals how much hp can they hold? I can easily get my hands on that
Old 07-30-2014, 08:44 PM   #35
Region: Nevada
What about a c4 a nice cooler a mvb and a torque converter? Would that last dauly driven on the streets? And some track abuse?
on3 turbo kit FordRacer_51 1979-1995 Mustang GT 5 04-21-2013 10:58 PM
on3 turbo s197 08mustanggt 2005-2010 Mustang GT 11 04-04-2013 11:07 AM
On3 performance turbo kit for S197. Graham1992 2005-2010 Mustang GT 2 07-17-2012 06:48 AM
On3 turbo fast 94 5.0 1979-1995 Mustang GT 11 06-27-2012 08:06 AM
On3 Turbo on 91 5.0 - follow up to 91 5.0 mostly stock thread JayKranz 1979-1995 Mustang GT 29 04-28-2012 09:33 PM
03:28 AM
