Random hose - Mustang Evolution
Old 07-25-2014, 08:25 PM   #1
kyle_rivas's Avatar
Random hose
Do I need to have this hose in this manifold it had a plug where it was supposed to be in the intake so I switched it from the stock intake to the cobra intake anf there is not a plug for it in the manifold do I need to have it? I dont think so but hust wondering?
galaxy s4
ID:	162261   Click image for larger version
kyle_rivas is offline   Reply With Quote
Old 07-26-2014, 01:05 PM   #2
ALMOST STOCK's Avatar
What is the other end of that rubber hose with the bolt in it hooked up to?
ALMOST STOCK is offline   Reply With Quote
Old 07-26-2014, 01:27 PM   #3
kyle_rivas's Avatar
Goes to the intake
galaxy s4
Old 07-26-2014, 02:09 PM   #4
Where?
Old 07-26-2014, 02:13 PM   #5
kyle_rivas's Avatar
Towards the back it screws in with the hose
galaxy s4
Old 07-26-2014, 02:22 PM   #6
Are you taking about the Stock or the Cobra intake?
Old 07-26-2014, 02:34 PM   #7
kyle_rivas's Avatar
This is my stock intake so I took the plug off of the cobra intake and put the hose from the stock intake to the cobra and it turns out it dosent fit
galaxy s4
Old 07-26-2014, 02:56 PM   #8
Someone before you capped the coolant lines from the EGR spacer off with that plug is the reason that plug is there.
Water/coolant passes thru the hole in the lower if it wasn't capped off.
Old 07-26-2014, 03:01 PM   #9
kyle_rivas's Avatar
So thats my problem? I don't think its hurting anything because it capped off pretty much
galaxy s4
Old 07-26-2014, 03:11 PM   #10
If it's capped off and you're not using the EGR spacer it's fine but if you've hooked up the hose that is carrying the water/coolant to a vacuum port you've got creamy colored oil.
I need this hose Mustangfan2003 1996-2004 Mustang GT 9 05-28-2008 01:46 PM
Name that vacuum hose... A5295 1979-1995 Mustang GT 3 11-27-2007 06:17 PM
hose sleeves and elbows whipster24 Mustang Parts for Sale and Wanted 0 04-25-2006 12:04 PM
fuel presure regulator hose? blk2kconvstang Pre-2005 V6 Mustang 0 03-07-2004 01:00 PM
06:17 PM
