Water problem - Mustang Evolution
Old 07-26-2014, 01:32 PM   #1
kyle_rivas's Avatar
Water problem
As most of u know I put the cobra upper and lower last night started it up big problem sounds like air is sucking somewhere dosent stay on all of the fluid from the radiator is comeing out of my exhaust something is really wrong I cant tell whats wrong unless I take it apart again just wondering if anyone knows of something I can do or what I did wrong I really have to get this thing back on the road before school or ima have to go out and buy a 2014 for mean time Big problem: Big problem - YouTube
galaxy s4
kyle_rivas is offline   Reply With Quote
Old 07-26-2014, 02:15 PM   #2
ALMOST STOCK's Avatar
I'd double check your hose routing... your sucking water/coolant in the engine and its running out the exhaust.
ALMOST STOCK is offline   Reply With Quote
Old 07-26-2014, 02:21 PM   #3
Alexanderv6's Avatar
Region: Oregon
Tough analysis . Id check the hoses like that guy said in the first comment. Other then that just do process of elimination, dont stress about it tho.
Alexanderv6 is offline   Reply With Quote
Old 07-26-2014, 02:29 PM   #4
kyle_rivas's Avatar
So my head gaskets are fine?
galaxy s4
Old 07-26-2014, 02:33 PM   #5
galaxy s4
Possibly!
Old 07-26-2014, 02:36 PM   #6
kyle_rivas's Avatar
Does anything look wrong?
galaxy s4
ID:	162288   Click image for larger version
ID:	162291   Click image for larger version
ID:	162293   Click image for larger version
Old 07-26-2014, 02:51 PM   #7
I'd still like to know where that rubber hose comes from that you have attached to the vacuum port that should go to the charcoal canister at the front of the intake?
Hopefully it's not hooked up to the heater tube port for the EGR because if it is that's where your problem is.. Water/coolant into a vacuum port = water/coolant out the exhaust sooner or later.
Old 07-26-2014, 02:56 PM   #8
kyle_rivas's Avatar
The black hose goes here
galaxy s4
Old 07-26-2014, 02:58 PM   #9
kyle_rivas's Avatar
Cobra intake
galaxy s4
Old 07-26-2014, 02:59 PM   #10
That is used for the EGR spacer and water/coolant passes thru it.
Old 07-26-2014, 03:02 PM   #11
kyle_rivas's Avatar
Is it the problem
galaxy s4
Old 07-26-2014, 03:05 PM   #12
Cobra intake
galaxy s4
That isn't going to the nipple at the front of the upper Cobra Intake is it.
HERE?
Old 07-26-2014, 03:08 PM   #13
Is it the problem
galaxy s4
If you have water/coolant going to a vacuum port it's a problem because you are sucking the water/coolant into the upper intake and then it's going into the engine and eventually coming out the exhaust.
Old 07-26-2014, 03:12 PM   #14
kyle_rivas's Avatar
So this is my problem?
galaxy s4
Old 07-26-2014, 03:22 PM   #15
YEP......That is EXACTLY your problem.
Your sucking in coolant and you shouldn't be!
Old 07-26-2014, 03:23 PM   #16
Problem solved.
Well other than draining the oil and replacing it and the filter a few more times that is.
Old 07-26-2014, 03:24 PM   #17
Region: Oregon
Originally Posted by ALMOST STOCK View Post
Problem solved.
Hahaha dance dance Revolution
Old 07-26-2014, 03:37 PM   #18
kyle_rivas's Avatar
Wait so how do I solve the problem?
galaxy s4
Old 07-26-2014, 03:45 PM   #19
With the Cobra intake you don't need that coolant line ... just cap. plug, seal that rubber hose off.
But you'll have a open vacuum port if you don't do something about that and if you don't have the charcoal canister just cap and seal that vacuum port off.
Do you still have the charcoal canister?
Old 07-26-2014, 03:51 PM   #20
kyle_rivas's Avatar
So where the hose going to the manifold and the to black lines on top of the intake do I need to take the hose off and seel the plug on the manifold and seel the plug on the other end of the hose?
galaxy s4
Old 07-26-2014, 03:53 PM   #21
kyle_rivas's Avatar
These?
galaxy s4
Old 07-26-2014, 04:03 PM   #22
Remove the black rubber hose from the upper intake and seal/plug/cap it off because you no longer need it with your Cobras intake.
By removing that black rubber from your Cobra upper intake you'll have vacuum leak .
If you still have your charcoal canister you need to hook back up the hose that once ran from under your stock upper intake to the vacuum port on your Cobra intake the charcoal canister.
If you don't have the charcoal canister you need to seal the vacuum port on your Cobra intake so that you don't have a vacuum leak.
Old 07-26-2014, 04:11 PM   #23
kyle_rivas's Avatar
Whats a charcoal canister?... im still kinda new from all this stuff this is my old manifold
galaxy s4
Old 07-26-2014, 04:11 PM   #24
Hellish Horse's Avatar
Wow Stock...you know a lot about this. Hope you're around in a couple months when I do mine.
Hellish Horse is offline   Reply With Quote
Old 07-26-2014, 04:24 PM   #25
galaxy s4
Your charcoal canister is located on the passenger side lower inner fender fender ( frame rail) .
The stock vacuum routing will look like the 1st attachment .
The 2nd and 3rd attachment are where you'll find the charcoal canister on your 89.
Old 07-26-2014, 04:28 PM   #26
Believe it or not it's just this simple.
Old 07-26-2014, 04:44 PM   #27
kyle_rivas's Avatar
Ok so this hose? I plug it up?
galaxy s4
Old 07-26-2014, 05:30 PM   #28
kyle_rivas's Avatar
When I have the vacuum hose pluged and the other thing pluged with my finger it sounds fine so now all I got to do is change my oil and my radiator fluid? And im good to go
galaxy s4
ID:	162320   Click image for larger version
Old 07-26-2014, 05:34 PM   #29
I just copied & saved the pics for future install. THX !!!
Old 07-26-2014, 05:42 PM   #30
kyle_rivas's Avatar
ALMOST STOCK I couldn't thank you enough for the big help thanks so much man if it wasn't for you id probably be screwed and took my hole motor apart thanks a lot man
galaxy s4
Old 07-26-2014, 06:05 PM   #31
smurf stang's Avatar
Like I have always said this man have every diagram or picture of fox bodies known to man.
Kyle you definitely need a Haynes or Chiltons at least.
2016 VW GTI 2.0 Turbo
Old 07-26-2014, 11:06 PM   #32
kyle_rivas's Avatar
What that lol...
galaxy s4
Old 07-26-2014, 11:22 PM   #33
kyle_rivas's Avatar
Wait can I hook up the hose that goes to the black canister into the manifold where u said it needs to be plugged just like the pic
galaxy s4
Old 07-27-2014, 09:00 AM   #34
NP... it always easier to do something when you have pics in front of you.
galaxy s4
I glad that I was able to help.
I'm much better with pics and diagrams than I am with text and why I usually post pics and diagrams.
Old 07-27-2014, 09:27 AM   #35
galaxy s4
If you still have your charcoal canister ???? Then the rubber hose needs to be hooked from the small vacuum port nipple in the front of the Cobra intake.
If you don't have the charcoal canister???? Then cap/plug the small vacuum port nipple off that is the front of the Cobra intake so that you don't have a vacuum leak.
Big problem-easy find, small problem-hard to find Dnraiders General Mustang Discussion 0 08-30-2011 11:10 AM
Problem with tube to Water pump! shipwreckedsoul Pre-2005 V6 Mustang 8 04-19-2011 05:15 PM
water pump replacement Ponycarman Pre-2005 V6 Mustang 3 01-16-2004 10:26 PM
water dripping on foot while driving Monkey Pre-2005 V6 Mustang 7 08-18-2003 04:41 PM
10:07 AM
