1995 mustang gt t5 swap issues... - Mustang Evolution
Old 07-26-2014, 09:57 PM   #1
Region: Nevada
Okay so I swapped my 1995 mustan. Gt to a t5 trans, immediately after I noticed that when I would beat on it hard it would buck at 4500, 4800, 5300 and not in every gear, I swapped everything over except the trans harness, now I pulled my codes today and got codes; 637, 654, 621, 622, 652, 624... They are all trans temp and shift solenoid fault codes, now the weird thing is that I swapped my PCM to a 5 speed mustang PCM and I'm still getting auto tranny codes? Is it cause I didn't change harness over for trans? Could this be causing my bucking issue? Is it possibly putting the car into a limp mode due to not knowing where it's shifting? Please help thanx
flatstanley1 is offline   Reply With Quote
Old 07-27-2014, 08:50 PM   #2
What is the code on your computer? T4M0 is manual GT and J4J1 is Cobra. If its not those, you didn't get a 5 spd trans. And yes, your trans harness should be swapped.
Old 07-27-2014, 08:52 PM   #3
Region: Nevada
It's t4mo I believe
1995 mustang
1995 mustang electrical issues flatstanley1 1979-1995 Mustang GT 0 07-11-2013 11:47 PM
1995 Mustang Cobra :: 1995 Ford Mustang Cobra jwhayne0001 Member Garages 0 08-20-2011 11:22 PM
1995 Mustang GT :: 1995 Ford Mustang Ripastanky Member Garages 0 06-15-2011 12:01 PM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
Can i swap my 1997 mustang gt rear end for a 1995 mustang cobra one? mathieu 1996-2004 Mustang GT 1 08-21-2009 01:40 PM
08:43 AM
