Soften clutch pedal - Mustang Evolution
Old 07-30-2014, 12:55 PM   #1
hd85's Avatar
Soften clutch pedal
Previous owner replaced the stock clutch with a stage 1 performance clutch not sure what brand but the pedal is pretty stiff and I'd like to have faster shifts from a softer pedal. Any way to soften the pedal?
hd85 is offline   Reply With Quote
Old 07-30-2014, 12:58 PM   #2
smurf stang's Avatar
Well without knowing which clutch, if it was installed correctly, if he lubed the clutch cable or in what condition the cable is in tough to tell.
2016 VW GTI 2.0 Turbo
Old 07-30-2014, 02:05 PM   #3
hd85's Avatar
Ill look at the cable when i get the chance. Aftermarket quadrant wont help?
Sent from my HTC6435LVW using Mustang Evolution mobile app
Old 07-30-2014, 02:49 PM   #4
Aftermarket quadrant and adjuster are good as the stock units are plastic, get brittle and brake. Will it make it softer no but it will help with adjusting and keeping it adjusted.
Old 07-30-2014, 04:57 PM   #5
hd85's Avatar
Alright could a longer cable help?
Old 07-31-2014, 04:36 PM   #6
Nope, only thing that might make a difference is if the PO did not use an OEM cable. Aftermarket cables are junk and are known to bind up and cause extra pedal effort.
But failing that the only way to lighten your pedal up is to get a new clutch.
Old 07-31-2014, 08:21 PM   #7
hd85's Avatar
Soften clutch pedal
Okay. I can live with it how it is. Is that just how staged clutches are? Or is it how it's installed?
Old 07-31-2014, 09:27 PM   #8
It depends on what clutch it is and if the cable is OEM or not. Some clutches are firmer than others and any non OEM cable is going to make it harder to push in.
Clutch Pedal Height Adjustment and Clutch Freeplay Mod ab_mach1 1996-2004 Mustang GT 126 10-20-2017 03:21 AM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
car moves with clutch pedal to the foor jedwards242000 Pre-2005 V6 Mustang 4 03-12-2006 12:05 AM
Look its fast64's clutch pedal assembly steedav6builder The Bar 14 04-09-2005 10:35 PM
clutch pedal sags? tedness Pre-2005 V6 Mustang 4 03-19-2005 11:10 AM
03:25 PM
