Help with fuel!!!! - Mustang Evolution
Old 07-30-2014, 02:14 PM   #1
Shifty 5.0's Avatar
Help with fuel!!!!
My fuel pump won't turn on!!! I jumped it at the test connector and it runs, I have power to all the wires at the fuel pump relay and in and out of the inertia switch, iv changed the fusible links and the relay to see if it'd work and it still won't turn on!!!! I'm in need of some major help
Shifty 5.0 is offline   Reply With Quote
Old 07-30-2014, 03:39 PM   #2
Liebert91stang's Avatar
So the inertia switch isn't popped?try smacking it to see if it works?also eec relay could keep it from starting.
Liebert91stang is offline   Reply With Quote
Old 07-30-2014, 04:44 PM   #3
Shifty 5.0's Avatar
Ohhhh iv tried a lot on the inertia switch and I can here the ECC relay click when I turn the key
Old 07-30-2014, 04:46 PM   #4
Have you recently done work to the fuel system?
Old 07-30-2014, 04:47 PM   #5
Shifty 5.0's Avatar
Here's where it started.... I did a wire tuck to put the starter solenoid and all the wires around into the inner fender, I get done and then the pump doesn't work. Iv changed the fuel pump relay and it's getting power just can't figure out why it won't turn on
Old 07-30-2014, 04:52 PM   #6
Shifty 5.0's Avatar
Old 07-30-2014, 05:09 PM   #7
If it was working before you did the tuck seems maybe a wire is pinched or maybe coating cut making it ground out.he is a troubleshoot on the fuel pump
---------- Post added at 05:09 PM ---------- Previous post was at 05:09 PM ----------
http://www.stangnet.com/mustang-foru...switch.876913/
Old 08-01-2014, 07:49 PM   #8
Shifty 5.0's Avatar
So there's no 12 volts to the injectors where should I check for problem first?
Old 08-01-2014, 08:47 PM   #9
ECM grounds or eec relay.sounds like something is grounded to me.wiring can be a *****
Old 08-01-2014, 08:52 PM   #10
Shifty 5.0's Avatar
I hate wiring the most but thanks I'm going to try to keep looking...it's been weeks and I can't figure it out
Old 08-01-2014, 09:16 PM   #11
Shifty 5.0's Avatar
Old 08-03-2014, 10:19 AM   #12
Shifty 5.0's Avatar
Does anybody know what wire off the starter solenoid powers the ECC? I the relay clicks but I'm not getting 12 volts to the injectors....I need to fight it out so my fuel pump will run so I can drive this sucker
Old 08-03-2014, 10:35 AM   #13
A bad eec relay will have check engine light,fuel pump won't prime and injectors won't fire.http://easyautodiagnostics.com/ford/...-relay-tests-1
Old 08-03-2014, 10:47 AM   #14
Shifty 5.0's Avatar
Thanks for this I'm going to go test the relay now! Iv heard that the relay will stick click even if it's bad, is that true? It would make sense because there's to circuits that need to open so one could be opening and still cause a click?
Old 08-03-2014, 11:33 AM   #15
Shifty 5.0's Avatar
Okay so Test 1 I get a good 12 volts...test 2-3 however give me each only 3 volts. Where is the inline fuse link for the power to these wires?
Old 08-03-2014, 11:34 AM   #16
ALMOST STOCK's Avatar
20 Gauge Blue fuse link … Black/Orange to ECC power relay.
ALMOST STOCK is offline   Reply With Quote
Old 08-03-2014, 12:10 PM   #17
Shifty 5.0's Avatar
Just replaced the fuse link it was bent and mushy so I'm going to test the relay again now.
Old 08-03-2014, 12:13 PM   #18
Shifty 5.0's Avatar
Replaced the link and it works!!!!!!!! Thanks for everyone who helped this has been a long couple weeks of a hassle. At least now I know about all the wiring in my fox after studying all the damn diagrams lol
Old 08-03-2014, 12:21 PM   #19
How about some pictures of that wire tuck you did that caused your problem?
Old 08-03-2014, 01:07 PM   #20
Nice find shifty.wiring usually is a bit**.glad you got it back on the road
Old 08-03-2014, 03:44 PM   #21
Shifty 5.0's Avatar
Il post pics when I get home tonight!
Old 08-03-2014, 03:50 PM   #22
Shifty 5.0's Avatar
Old 08-03-2014, 06:48 PM   #23
Shifty 5.0's Avatar
Name:	ImageUploadedByMustang Evolution1407113259.170372.jpg
ID:	162804 before and afterClick image for larger version
Name:	ImageUploadedByMustang Evolution1407113281.889638.jpg
Old 08-03-2014, 08:12 PM   #24
Old 08-04-2014, 03:22 PM   #25
Nice work.i need to replace altonator and tuck on mine.does it feel good to get it back on the road?
Old 08-04-2014, 09:52 PM   #26
Shifty 5.0's Avatar
Yeah it feels great lol I missed the power and the shaking of the car from the came
need help with custom fuel rails, fittings, fuel pressure gauge tire Pre-2005 V6 Mustang 2 07-13-2015 03:32 PM
Replacing stock fuel door with stock fuel door...help? MarshallYoung 2005-2010 V6 Mustang 13 07-23-2012 11:23 PM
Pruchased my Fuel Injectors and Fuel pump today Brent Pictures and Videos 36 12-14-2010 03:22 PM
Help help- fuel pump-help! The Darkside Pre-2005 V6 Mustang 26 05-08-2009 01:45 PM
19LB Fuel Injectors; 190-255LPH Walbro Fuel Pump Brent Mustang Parts for Sale and Wanted 5 05-11-2005 11:04 PM
05:15 AM
