How to remove the iac? - Mustang Evolution
Old 07-31-2014, 08:01 PM   #1
95gt 5.0
How do you get the lower screw out
I got the top 1 with a 5/16th socket but can't get the socket in the lower 1 even with a swivel!!!
Am I a idiot or is there a trick to it? Everything I've read says to use a 8mm or 5/16th socket.
I have a 8mm socket but it's deep well & won't fit as there isn't very much room between the screw and a black looking pipe running on top of the valve covers. Also I noticed when I use my shorter 5/16 it won't go on because there is a curve on the IAC above the screw that seems to intrude the way!!
HELP PLEASE AS I NEED TO CLEAN THE IAC
egull64 is offline   Reply With Quote
Old 08-01-2014, 07:03 AM   #2
jasondanger's Avatar
Im pretty sure you need to remove the throttle body to get the bottom bolt out of the iac. Its only 4 bolts hoding it on, no big deal.
jasondanger is offline   Reply With Quote
Old 08-01-2014, 09:16 PM   #3
Whew....Just got done cleaning it & putting back on
Had to take the throttle body off but wasn't that difficult to do & mine was DIRTY!!
Thanks to everyone
Old 08-04-2014, 09:11 AM   #4
smurf stang's Avatar
Well did it help the problem if there was one?
2016 VW GTI 2.0 Turbo
Old 08-04-2014, 10:56 AM   #5
Not that I can tell but I only ran it for 10 minutes being the radiator is cracked. Seemed to still idle real bad & I've cleaned everything. MAF, IAC & THRITTLE BODY....any suggestions?
Old 08-04-2014, 03:23 PM   #6
Liebert91stang's Avatar
Changed plug and wires lately?
Liebert91stang is offline   Reply With Quote
Old 08-04-2014, 03:57 PM   #7
Changed plugs 11/9/13 & inspected wires(they looked fine) Only drove the car maybe 5k since I changed. Oh new dizzy 1/14 coil, rotor, cap tps & efi
Old 08-04-2014, 03:59 PM   #8
I meant the tfi (control module) not efi.....lol
Old 08-04-2014, 05:41 PM   #9
May try remove plugs from cap one at a time while it's running to see if idle changes.plug wires can look fine but be bad internally.battery post have corrosion?also may be fuel injector
To remove fogs or not to remove fogs SystemCritical 2011-2014 Mustang GT 64 05-23-2013 07:10 PM
Polished my IAC 97Stallion Pictures and Videos 5 01-08-2005 01:27 PM
IAC Valves 97Stallion Pre-2005 V6 Mustang 4 08-30-2004 11:35 AM
Where does the IAC go? Horse Pre-2005 V6 Mustang 4 01-23-2004 09:26 PM
possible IAC problem? HELP!? Horse Pre-2005 V6 Mustang 0 12-10-2003 12:59 PM
09:48 AM
