Battery problem - Mustang Evolution
Old 08-01-2014, 12:22 PM   #1
kyle_rivas's Avatar
Battery problem
I was gone at church camp and came hole excited to drive my mustang but noooo the dam battery was completely dead and I put a brand new battery in and went to sonic and back home no problem woke up for work that battery is screwed and dead so I missed a day no ride does anyone know whats going on I already disconnected my cig lighter my system fuses are all good the only thing I can think is my altinator isnt working because I just charged it a little bit drove about a mile did a burn out came home turned it off "clickkkkkkkkkkkkkk" it was dead again I dont think its charging
galaxy s4
kyle_rivas is offline   Reply With Quote
Old 08-01-2014, 02:45 PM   #2
Semerollin's Avatar
Go to auto zone and have them check your charging system to see if the alternator is charging properly.
Semerollin is offline   Reply With Quote
Old 08-01-2014, 02:57 PM   #3
smurf stang's Avatar
Check the battery.
Check the alt.
Check the ground cable and ground straps.
Check to see the sunvisor light to see if it stays on.
Check to see if any lights stay on.
I hate shorts if that is what it is.
2016 VW GTI 2.0 Turbo
Old 08-01-2014, 03:36 PM   #4
BlackPonyIHave's Avatar
Use a multimeter. Remove the ground clamp and put the meter on its 10 amp range between the clamp and the battery post. Any reading over 0.1 amps indicates a problem, something drawing power in your car. You can narrow this down by removing a fuse at a time from the fusebox until the current draw disappears.
4.6 engine,Ford Racing torque bar, diablo performance 93 octane tune, cold air intake with a K&N filter, SLP exhaust from axle back, 3.73 ford racing gears
BlackPonyIHave is offline   Reply With Quote
Old 08-01-2014, 03:38 PM   #5
Semerollin's Avatar
+ 100
Old 08-01-2014, 03:55 PM   #6
I think it has to be the charging system.
I don't know what year Mustang he has but if it is a newer one it shuts everything on the car off after you take the key out after about 15 minutes.
The OP really needs to do what Semerollin says:
Taking out fuses is not going to repair a bad alternator.
Old 08-01-2014, 05:39 PM   #7
kyle_rivas's Avatar
I went to advanced auto parts and they said my battery is to dead to see whats going on
galaxy s4
Old 08-01-2014, 08:44 PM   #8
Battery chargers are not to expensive
Charge the battery and go back to get the charging system checked out.
*******************************or*****************************************************
The new battery you bought could be bad from the start from sitting in the store way to long.
Just don't start tearing your car apart before having these checked out.
Old 08-01-2014, 11:21 PM   #9
kyle_rivas's Avatar
It was a altinator
galaxy s4
Old 08-02-2014, 07:26 PM   #10
Wow,
I'm sure happy you found out what it was before yanking fuses and fooling around with wiring and stuff.
PLEASE HELP battery problem Nick Proben 1979-1995 Mustang GT 7 04-17-2013 04:19 PM
Battery problem? TM2189 Pre-2005 V6 Mustang 6 04-01-2013 07:05 PM
battery problem CasperHornyV6 Pre-2005 V6 Mustang 1 06-20-2012 02:52 AM
battery charging problem I_luv_HP&trq Pre-2005 V6 Mustang 20 09-24-2005 02:58 AM
10:37 AM
