Axle shaft - Mustang Evolution
Old 08-03-2014, 10:02 PM   #1
Minus2380's Avatar
Axle shaft
I have a 95 gt and need to replace the driver side axle shaft. My question is....is it hard to do? And do I need any special tools? Any input would help a lot!!! Thanks
Minus2380 is offline   Reply With Quote
Old 08-05-2014, 05:54 PM   #2
94_2valves's Avatar
No not really. Other then hands tools, you'll need a slide hammer with a attachment for removing rear axle seals. You can get these at any auto parts store. Remove the brakes and abs sensor. Open the diff and push the axle inward exposing the end of the axle and the c clip. Remove the clip and the staff will slide out. Good luck
94_2valves is offline   Reply With Quote
Old 08-05-2014, 09:33 PM   #3
havhammer's Avatar
You can pop the axle seal out with a prybar. If your gonna change the outer axel bearing then you will need the slide hammer and jaw attachments. Or take both axles out and pound it out from the other side. Dont forget the friction modifier if the 95's still used it,when you go to fill it up.
Sent from my SPH-L710 using Mustang Evolution mobile app
havhammer is offline   Reply With Quote
Old 08-06-2014, 05:20 PM   #4
Minus2380's Avatar
Right on thank you guys. Gonna do this on Friday.
New Axle Shaft Question Stanglover1966 Classic Mustangs 0 07-27-2014 06:59 PM
Drag tires, axle and drive shaft crev 2011-2014 Mustang GT 31 05-28-2014 03:41 PM
2010 Rear Axle Shaft Issues ElGrandeBurrito 2011-2014 Mustang GT 2 08-02-2013 12:03 PM
Rear Axle Shaft Sycopath80 2005-2010 V6 Mustang 4 04-04-2012 03:25 PM
1965 Mustang 200ci drive shaft and axle Tuch65 Classic Mustangs 6 11-06-2011 11:39 AM
02:21 AM
