95 Cobra to 89 fox disc and brake swap. - Mustang Evolution
Old 08-05-2014, 12:27 PM   #1
89 5.0 stang's Avatar
Was wondering if I'm missing anything, going to the scrap yard dont want to go twice.
Things I'm pulling:
-master cylinder with hydro booster
-spindles
-hubs
-rotors with calipers and lines
Anything else?. I already have rear axle from a v8 sn95.
Sent from my HTC Sensation 4G using Mustang Evolution mobile app
89 5.0 stang is offline   Reply With Quote
Old 08-05-2014, 12:29 PM   #2
doing a 5 lug and disc swap Was wondering if I'm missing anything, going to the scrap yard dont want to go twice.
Things I'm pulling:
-spindles
-hubs
Old 08-05-2014, 12:38 PM   #3
silverstone's Avatar
Brake cables. They will be longer.
silverstone is offline   Reply With Quote
Old 08-05-2014, 05:07 PM   #4
Thanks I think I'm going steel braided anyways. Anything else?
Old 08-05-2014, 05:16 PM   #5
Need spindles for 94-95. 96-04 you will need to change k-member. Maximum motor sport has a k-member that's adjustable. Found mind on eBay.
Old 08-05-2014, 06:42 PM   #6
Is there a difference in rotor or caliper size between the 95 Cobra to the sn95 model?
Old 08-05-2014, 06:50 PM   #7
Good luck finding a cobra not stripped down. If you find a 94-95 cobra get the spindles and all for calibers and rear brackets. Just need read brake lines.
Old 08-06-2014, 09:47 AM   #8
Ok thank you for your help..I'm sure ill have some more questions soon.
Old 08-20-2014, 06:38 PM   #9
Well turns out the junk yard tried to sell me the wronge parts...long story but got my money back....now I'm just thinking of other cheap ways to do a 5 lug disc swap with Cobra fronts. Any ideas? I was just gonna order every thing from auto zone lol slap the new parts on.
Old 08-20-2014, 09:13 PM   #10
Nothing cheap about it. Think I spent 1400 without wheels. Doing it the right way.
Old 08-21-2014, 12:55 PM   #11
Go to JY, pull the SN95 spindles and whatever other parts yourself, then order a set of new PBR calipers and brackets from wherever (rockauto has them) for the fronts. For the rears you'll need to do caliper mount brackets when you pull the axles for the 5 lugs plus the cobra caliper brackets and you can use any 94-04 rear calipers since they are all the same.
Figure you'll spend $300 shipped for a good quality new Cobra rotor/pad setup. Another $40-$50 for good used rear calipers, $50 for rear Cobra caliper brackets, $150 for the caliper bracket rear mounts, $250-$300 for Cobra front calipers and brackets, plus the cost of whatever you pull from the JY like the spindles/lines/rear axles etc... Its not cheap, $1400 is a little more expensive than I've seen some done for but its not the most expensive I've seen either.
A much cheaper and still effective setup is to do a 99-04 GT brake setup. They had dual pistons calipers up front but not the big rotors the Cobras had. They still stop LIGHT YEARS better than the fox setup and even the 94-98 GT setup.
Anyone willing to swap their single disc cd for a 6 disc? Ou7LaW Mustang Audio & Video 0 06-30-2014 11:10 AM
Fox body aerospace rear disc brakes 2300turboford Mustang Parts for Sale and Wanted 1 12-22-2012 01:05 PM
The Red disc brake Caliper covers ??????? ronnie948 2011-2014 V6 Mustang 27 07-09-2012 12:52 PM
Disc brake conversion for 66 Mustang Seattle66 Classic Mustangs 9 01-25-2012 10:52 AM
Disc brake conversion kits Bravebowhunter Classic Mustangs 7 02-28-2011 08:00 PM
04:28 PM
