89 mustang won't rev past 4000 - Mustang Evolution
Old 08-06-2014, 09:45 PM   #1
Vazqueza90's Avatar
Fox won't rev past 4000 sounds like it's hitting a limiter
No cats straight pipe to flowmasters(had these since my dad got it in '97)
Thnx in advance
Vazqueza90 is offline   Reply With Quote
Old 08-06-2014, 11:38 PM   #2
Vazqueza90's Avatar
Bump
Old 08-07-2014, 07:26 AM   #3
Infantry09's Avatar
Rev limiter on the ignition
Infantry09 is offline   Reply With Quote
Old 08-07-2014, 08:49 AM   #4
smurf stang's Avatar
Have you run your codes?
What's your timing at?
What's your fp at?
Great place to start.
And posting at night and bumping 2 hours later is an exercise in futility.
2016 VW GTI 2.0 Turbo
Old 08-07-2014, 10:09 AM   #5
Vazqueza90's Avatar
Bump
Old 08-07-2014, 10:11 AM   #6
Vazqueza90's Avatar
Have msd set to 6000
Old 08-07-2014, 10:16 AM   #7
Vazqueza90's Avatar
What's your fp at?
No I haven't
Timing is advanced to *14
FP is at 32
My phone posted it randomly
Old 08-07-2014, 02:37 PM   #8
Pull your codes................BUMP and report back.
Old 08-19-2014, 02:52 PM   #9
Vazqueza90's Avatar
Just pulled the codes today
21, 33, 88, 94
Old 08-19-2014, 04:27 PM   #10
Vazqueza90's Avatar
21, 33, 88, 94
Old 08-19-2014, 06:36 PM   #11
Vazqueza90's Avatar
Bump
Old 08-20-2014, 08:36 AM   #12
21- ECT Sensor Out Of Self Test Range
33 - EGR Valve Opening Not Detected
88 - Loss Of Dual Plug Input Control
94 - Secondary Air Injection Inoperative. bank two, driver side
Did this just happen out of nowhere or has this been getting worse?
Do you still have your EGR or is it deleted?
ECT sensor is probably bad.
What happens when you hit 4k. Does it hit you like a rev limited like you said?
The FP, when you pulled the vacuum line did the pressure go up to 38 or 40? Also try different rpm ranges when you have the gauge set up. The pressure should stay about the same. If it drops then there is a problem.
When was the last time she had a tune up? New wires, plugs, cap, rotor, fuel filter?
Start with the simple like a fresh tune up. Start and check for vacuum leaks. Check the condition of the balancer to make sure it hasn't spun. Now it might be that your coil is on it's way out as it happened to me once with a bad MSD coil. Also it could be that your fuel pump might be on it's way out also.
Old 08-20-2014, 10:54 AM   #13
Vazqueza90's Avatar
We'll I thought that it would just go up to 3500-4k but my friend has a mustang also and he said easily the car can go to 5-5800k that's when I first noticed the problem..
EGR is still on the car..
I read the codes when the car was cold that could've been why it thru out the code right.?
This is what happens when it hits 4k
http://youtu.be/oITDoL-ZxVw
What vacuum line do I pull to check the FP.?
I'm going to do a tune up on the car this weekend 'cause I don't know how long it's been since my dad gave it to me
How do u check the balancer.?
Just dropped in a new fuel pump 190lph and a fuel filter this past weekend
Old 08-20-2014, 12:37 PM   #14
Yes the car must be at operating temp.
The vacuum line you pull is on the fp regulator.
Physically and visually check the balancer to see if there is rubber sticking out or if it has spun on the hub.
If the EGR is bad it could be stuck open or closed. That would be a vacuum leak there also.
Give her a good once over and lets see what happens after that.
Also make sure you have the proper firing order for the plug wires.
good luck.
Old 08-28-2014, 02:15 PM   #15
Vazqueza90's Avatar
Did a complete tune up wires,cap and rotor, spark plugs checked all the wires see if they r firing right..
Same problem
Old 08-28-2014, 07:52 PM   #16
Liebert91stang's Avatar
Does it still have catalyc converter on exhaust?could be stopped up
Liebert91stang is offline   Reply With Quote
Old 08-28-2014, 08:48 PM   #17
Just noticed it has no cats.does the Msd have the rev limiter on it?
Old 08-29-2014, 08:10 AM   #18
Vazqueza90's Avatar
Yes it does 6k
Old 08-29-2014, 08:48 AM   #19
Originally Posted by Vazqueza90 View Post
Yes it does 6k
I would say that is your problem.thats where I would be looking to solve the issue.cant think of anything else that would keep it under a certain rmp that doesn't have some kind of a governor on it
Old 08-29-2014, 01:45 PM   #20
Vazqueza90's Avatar
I'm going to disconnect it see if that's the problem
Lookin at 90 mustang gt rust free $4000 l Sambrostang 1979-1995 Mustang GT 5 03-01-2012 09:55 AM
For Sale: 1998 gt $4000 obo Nate98stang Mustangs for Sale and Wanted 2 07-30-2011 03:12 PM
Trying to unhook the rpm mine is peging at 4000 like to have more? pierre 1996-2004 Mustang GT 1 08-19-2009 12:28 AM
1996 V6 in Boston, $4000 OBO mexor Mustang Parts for Sale and Wanted 0 05-31-2004 06:22 PM
10:10 AM
