Solenoid working or not - Mustang Evolution
Old 08-11-2014, 03:47 PM   #1
Foxbody91's Avatar
Ok past few days my 91 has had trouble starting. First time I tightened connections on battery it fired up just fine. 2nd time I added a bit if water to battery it fired up just fine again. I took battery to get tested and it's fine so I figured must b connections again so I cleaned terminals and retightened everything it fired up. 10 min later it won't start again. When I turn key it nothing happens. A slight clunk and that's it. Sometimes I can still get the radio on and lights sometimes they don't. I'm starting to think its my starter solenoid so how do I know if it's working or not and where do I go from here. And if it helps I'm EFI
Foxbody91 is offline   Reply With Quote
Old 08-11-2014, 07:38 PM   #2
Foxbody91's Avatar
Click* not clunk
Old 08-12-2014, 06:30 PM   #3
Liebert91stang's Avatar
Solonoid should have 12 volts on sided from battery wire .after you turn key should have 12 volts on other side
Liebert91stang is offline   Reply With Quote
Old 08-12-2014, 10:07 PM   #4
kyle_rivas's Avatar
Hey man im pretty sure its your altinator I had the same exact problem did EXACTLY what you did turns out my altinator was bad just take your old one on to orilles or somewhere and they will give u a deal on a brand new one
galaxy s4
kyle_rivas is offline   Reply With Quote
Old 08-12-2014, 10:24 PM   #5
Foxbody91's Avatar
Alternator is barely a year old
Old 08-13-2014, 12:06 AM   #6
kyle_rivas's Avatar
Still could be that... do you charge your battery and over night it dies? Same problem I had my altinator was grounding out idk something in the inside and caused the battery to die
galaxy s4
Old 08-13-2014, 02:48 AM   #7
Foxbody91's Avatar
Old 08-13-2014, 02:49 AM   #8
Foxbody91's Avatar
Idk y that posted twice. But no I haven't had to charge the battery yet I can still turn on lights and radio
Old 08-13-2014, 04:24 AM   #9
Sounds like it's the starter to me
Old 08-14-2014, 01:29 PM   #10
Foxbody91's Avatar
Ok took starter out had it and the cable tested they were both fine. My solenoid isn't cracked or burned so ima take out ignition switch now. Any other suggestions?
Old 08-14-2014, 01:39 PM   #11
Foxbody91's Avatar
Old 08-14-2014, 03:15 PM   #12
Do you have ground to motor and chasis?
---------- Post added at 03:15 PM ---------- Previous post was at 03:14 PM ----------
May check ground wires to make sure they aren't corroded.hoe about altonator?
Old 08-14-2014, 06:04 PM   #13
kyle_rivas's Avatar
Look for anything grounding out especially if you have a speaker system
galaxy s4
Old 08-14-2014, 08:30 PM   #14
Foxbody91's Avatar
No wires grounded, I haven't really inspected alternator that much I haven't gotten tested cuz it's new but I guess it won't hurt to eliminate all possibilities .
Old 08-15-2014, 03:35 AM   #15
kyle_rivas's Avatar
All you have to do is get the car started and unplug one connection from the battery and if the car stays running your altinator is ok and your battery is bad if your car turns off after you disconnect its your altinator thats a easy test right there
galaxy s4
Old 08-15-2014, 06:58 PM   #16
Foxbody91's Avatar
Yea it'd b amazing if I can get it to start lol. I bought a new solenoid but it was the wrong one, I put it on anyways just to test it and see if car would turn but still nothing but lights and radio. So I'm taking the solenoid back and getting the right one and ima try it. Once I get off work ima check all my connections with alternator but I also tried to jump start my battery yesterday(with a chevy 😞) and it still did nothing. Is it the starter still, shud I take it back off and get it tested somewhere else?
Old 08-15-2014, 07:34 PM   #17
Are your battery terminals tight?jump starting it should work.does the pump prime when you turn the key?
Old 08-15-2014, 10:19 PM   #18
kyle_rivas's Avatar
I tryed to jump start mine with a chevy and still didn't work either man lol
galaxy s4
Old 08-16-2014, 08:19 AM   #19
Foxbody91's Avatar
I've tried jumping it twice lol ironically the first time a friend of mine in his 2012 boss jumped me it started right up. Second time the Chevy was a no go. But yea I tightened my terminals still nothing, but I had my gf buy another solenoid while I was at work, gave her the old one and a pic of the exact same one I should have, the guy who tested my starter still gave her the wrong one. Starting to rethink taking starter out and get it tested somewhere else. I put the new solenoid in best I could just see if it would work and still nothing
Old 08-16-2014, 08:20 AM   #20
Foxbody91's Avatar
And by pump u mean fuel pump? If so I'm carbureted
Old 08-16-2014, 10:23 AM   #21
kyle_rivas's Avatar
Have you tryed what I told you?
galaxy s4
Old 08-16-2014, 12:21 PM   #22
Foxbody91's Avatar
Lol na I haven't been able to get it started for almost a week now, jumping it didnt work, I have a hill close by I could push over the hill and pop the clutch u think that will work??? Wasn't sure since it isn't starting at all
Old 08-16-2014, 01:51 PM   #23
kyle_rivas's Avatar
Lol thats the way to do it
galaxy s4
Old 08-17-2014, 02:40 PM   #24
Foxbody91's Avatar
It's clearly my starter or solenoid so quick question..the solenoid I have has 4 terminals on it, the one I see that I can order for my yr mustang has 3 and 4 terminals on them but they aren't the exact same as my current solenoid. Does it matter?
Old 08-17-2014, 02:44 PM   #25
Foxbody91's Avatar
Name:	ImageUploadedByMustang Evolution1408308068.357729.jpg
ID:	163675 these are the ones I see to order
Name:	ImageUploadedByMustang Evolution1408308210.419050.jpg
ID:	163676 and this one is mine, 4 terminals 2 in the middle 2 on each side
Old 08-17-2014, 03:23 PM   #26
Foxbody91's Avatar
I just looked up my solenoid its for fords 60'-71' it's an aftermarket part also...now I'm really confused
Old 08-17-2014, 03:54 PM   #27
Test the starter solenoid by connecting a jumper cable to the battery side of the solenoid. The solenoid has two large posts and two small posts. A single large post is located on either side of the solenoid. Attach the alligator clip of the jumper cable to the large post on the battery side of the solenoid. Touch the opposite end of the jumper cable to the large post on the other side of the solenoid. If the starter turns the engine normally, the problem likely lies with an ignition override switch, such as a clutch start switch or a neutral safety switch. If the starter produces a buzzing sound, the starter is likely defective. If there is no response at all, the solenoid is defective and must be replaced.
Old 08-17-2014, 04:25 PM   #28
Foxbody91's Avatar
Does it matter if its the positive or negative side of jumper cables?
Old 08-17-2014, 04:35 PM   #29
Foxbody91's Avatar
And do I hook up to battery also? Sry if questions r dumb I've never done electrical work on my car
Old 08-17-2014, 04:55 PM   #30
Just use the positive side but it doesn't matter as long as your using the same colors
Old 08-17-2014, 05:24 PM   #31
Foxbody91's Avatar
I put positive cables on both ends of solenoid it started sparking...do I try to crank now or wat???
Old 08-17-2014, 05:54 PM   #32
Foxbody91's Avatar
It buzzed...hooked cables up to gfs battery on her car then to my solenoid, tried to crank and it buzzed
Old 08-17-2014, 05:55 PM   #33
Sounds like the starter to me
Old 08-17-2014, 05:55 PM   #34
Foxbody91's Avatar
Cool preciate the help. Ima order a new one and get it in and see what happens
Old 08-17-2014, 05:57 PM   #35
Good luck.let us know what's the result
A\C working then not working Bohogin Pre-2005 V6 Mustang 3 07-14-2011 01:44 PM
1976 ford mustang will not start, not headlights come on, it is not the battery, why? eifion Classic Mustangs 6 08-24-2009 03:12 AM
cannister purge solenoid 98mustang2007 Pre-2005 V6 Mustang 4 10-10-2007 11:35 AM
nitrous fuel solenoid installation Zim Pre-2005 V6 Mustang 8 11-13-2003 06:19 AM
03:19 AM
