Car issues - Page 2 - Mustang Evolution
Old 09-01-2014, 12:07 AM   #36
SexiLilFox's Avatar
How much could that cost to get all that.
SexiLilFox is offline   Reply With Quote
Old 09-01-2014, 12:11 AM   #37
The cap and rotor is probably around $20.
PCV is less than $5.
And $5 or $6 for the can of MAF cleaner.
$20 for the spark plugs.
Old 09-01-2014, 12:12 AM   #38
SexiLilFox's Avatar
Not bad yeah I think may just go ahead and replace those things on my car then cause sounds like they are definitely something that needs to be done
Old 09-01-2014, 12:17 AM   #39
Those items are all part of a complete tune up.
If you have any questions when you clean the MAF sensor, don't hesitate to ask...
Old 09-01-2014, 12:35 AM   #40
Karbuster's Avatar
You guys just love giving me work to do...
posted using smoke signals
Using Tapatalk
Karbuster is offline   Reply With Quote
Old 09-01-2014, 03:34 PM   #41
Karbuster's Avatar
Cleaned MAF sensor and pulled some random useless wiring that went nowhere (aftermarket home install speaker crap), trying to figure out why her turn signals aren't working, from the poking i did, it looks like the flasher was eliminated when the viper alarm was installed so where should I look for a fuse/short or whatnot
Urgent, need help fast, hazards work, turn signals don't, flasher eliminated when viper alarm was installed, jumped car recently, how screwed are we
Using Tapatalk
Old 09-02-2014, 10:07 AM   #42
Karbuster's Avatar
Cmon guys, she really shouldn't be driving it without turn signals, our local police can be really picky when it comes to muscle cars
Using Tapatalk
Old 09-02-2014, 10:18 AM   #43
SexiLilFox's Avatar
Wrong post babe
Old 09-02-2014, 11:50 AM   #44
Haha.
You need to check the fuse and if your flasher was removed to install an alarm system, then that is the most obvious place to start looking for the problem.
Until you fix it, you are just going to have to use "hand signals" to alert drivers of your intentions.
Do it like an old school 1% biker does... Middle finger in the air when signalling a right turn.
Start a new thread if you want some help with your problem Karbuster...
Old 09-02-2014, 12:00 PM   #45
SexiLilFox's Avatar
I forget which signal is right and which signal is left. I haven't used hand jestures since drivers ed my junior year of high school. God was that really 4 years ago. Wow.
Old 09-02-2014, 12:16 PM   #46
Right turn: Left arm out and bent 90 degrees and pointing up.
Left turn: Left arm extended straight out.
Stop: Left arm out and bent 90 degrees and pointing down.
Old 09-02-2014, 12:21 PM   #47
SexiLilFox's Avatar
Thanks very much
Old 09-02-2014, 12:22 PM   #48
99_GRUMPY_GT's Avatar
What happens if they get confused and stick both arms out the window?
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 09-02-2014, 12:25 PM   #49
If you're going fast enough, your arms will act like airplane wings and that sucker could get airborne!
Old 09-02-2014, 12:30 PM   #50
SexiLilFox's Avatar
Lmao
Old 09-02-2014, 12:36 PM   #51
Or fall out
Old 09-02-2014, 12:48 PM   #52
Lol
Old 09-03-2014, 07:15 AM   #53
Karbuster's Avatar
Related to the cracked header, does anyone know the catalytic laws in Washington? If she registers it as a classic is she bound to the laws of regular consumer vehicles?
Using Tapatalk
Old 09-03-2014, 07:37 AM   #54
Originally Posted by SexiLilFox View Post
Also I found this while under my hood. Is that supposed to look like that.Attachment 163600
I do not see a crack in the header, I see a pinch where the header tube was fabbed at the manufacturer, but I do not see a crack. So I do not know where you are talking about a cracked header. If there was a crack in the header, no matter where, it would have blackish soot around the crack where the exhaust gases would have escaped, even around the header flange. And I do not see that either.
Old 09-03-2014, 07:38 AM   #55
I am assuming you are with the OP since you keep jumping in on this thread? Or are you confused and think you are in a thread of your own?
Old 09-03-2014, 07:51 AM   #56
Karbuster's Avatar
I am with op, I'm her resident mustang mechanic and I figured I have to do most of the work anyway so why not ask the questions?
Using Tapatalk
Old 09-03-2014, 02:59 PM   #57
SexiLilFox's Avatar
Lol not just my mechanic. My boyfriend too
Old 09-03-2014, 03:59 PM   #58
Old 09-03-2014, 04:25 PM   #59
Lol.
I thought Karbuster was a Hijacker...
Old 09-03-2014, 05:03 PM   #60
Lol.
I thought I was the only one!
Old 09-04-2014, 08:28 PM   #61
Karbuster's Avatar
So I'm pretty sure it's the brain of the viper alarm, whether it's a fuse for the brain or the brain itself I don't know, does anyone know what I'm supposed to be looking for? And if the brain is bad how hard is it to swap the brain for a new/different one? She has the keyless entry installed currently and we have the next one up (remote start) waiting to go in when we had the need/money, is it plug and play or is it a nightmare?
Using Tapatalk
Old 09-04-2014, 09:05 PM   #62
If it were me, I get rid of that alarm system altogether. But then again, what do I know. I have always thought of viper alarm is a POS system.
Old 09-04-2014, 09:07 PM   #63
Karbuster's Avatar
Well it's in there and I sure as hell ain't taking it out... That would just be the worst project in the history of hellish projects
Using Tapatalk
Old 09-05-2014, 10:45 AM   #64
SexiLilFox's Avatar
I need an alarm system because I've got a sound system in my car with amp and subwoofer. That's the reason I got the alarm so no one can just walk up bust a window and take it
Old 09-12-2014, 01:21 PM   #65
Karbuster's Avatar
Found the turn signal flasher and replaced it, someone had relocated it and tucked it under the dash like a boy pretending to be a girl
Using Tapatalk
Old 09-12-2014, 06:04 PM   #66
SexiLilFox's Avatar
This was a different issue. Not the turning signal issue. That was a different post and I already said that
Car is in the shop with mechanical issues- have a ? mikeygaga 2011-2014 V6 Mustang 9 08-05-2014 11:35 AM
New car issues Matticus SVT Mustang 24 02-14-2014 10:35 PM
Car issues 05stangGT 2005-2010 Mustang GT 14 12-17-2013 04:04 PM
just put auto trans in standard car having issues with going forward B Wilkey Pre-2005 V6 Mustang 9 03-26-2013 05:10 PM
The guy turned in his Car Title and I want to buy his car. How do I get a new Title for the car? stanley General Car Discussion 2 04-10-2010 09:45 AM
07:38 PM
