Ignition issue - Mustang Evolution
Old 08-15-2014, 10:58 PM   #1
OneSlow95's Avatar
Ignition issue
When i turn the key, I get absolutely nothing. No crank or the motor turning over at all. After a handful of times turning the ignition ill get the starter to engage, then another time and ill hear the stater try again, and again until it kicks on (and then it runs perfectly fine). sometimes ill sit there and do this for a couple mins before i hear anything. the lights will flicker once but thats it. after the first turn, the dash wont flicker. I have checked all of the connections and wiring to the battery (its relocated to the trunk with a kill switch) all wiring is fine. This problem started not too long ago. I have a full MSD ignition set up. brand new plugs, wires, etc. my alternator is fine as well. Was wondering if anyone else has had similar problems such as this. It doesnt happen every single time, just almost about every other time. its almost as if the battery is disconnected for the first 5 attempts at trying to start the car, then it will slowly make progress. was thinking about starting with replacing the battery (since im not 100% how old it is, kinda looks like a no name walmart brand). It is a 95gt manual. Any suggestions are greatly appreciated, thanks.
OneSlow95 is offline   Reply With Quote
Old 08-16-2014, 12:00 PM   #2
It probably is related to your battery and the 10 feet of battery cable that you are using.
Where is the negative side of the battery grounded to? Does it go back to the engine block?
An easy "backyard" test to tell if the battery is at fault is to hook up some jumper cables to your battery and jump it from a running vehicle and see if your starting problem disappears.
Old 08-16-2014, 01:34 PM   #3
OneSlow95's Avatar
That's a good point, I'm not entirely sure since I pretty much have 0 time during the weekend with my car I work double and triple shifts on the weekends so I won't be able to figure it out until Monday. Just thought if get some ideas before Monday comes around. And for some reason my truck doesn't pop open anymore, ever since the car developed this issue it doesn't unlock (doubt its related) but its just that much more difficult to get to my battery now
Sent from my SCH-I605 using Mustang Evolution mobile app
95 GT conv. ignition timing issue Jar72 1979-1995 Mustang GT 11 10-05-2012 05:20 PM
msd ignition ****** theglory 1979-1995 Mustang GT 11 09-19-2005 08:47 AM
ignition question plstktnkr2 Pre-2005 V6 Mustang 4 01-19-2004 10:49 PM
NOS ignition controllers TheSarge Pre-2005 V6 Mustang 3 09-16-2003 09:19 PM
Better ignition for 98.... TheSarge Pre-2005 V6 Mustang 2 09-15-2003 09:43 PM
11:54 PM
