Exhaust - Mustang Evolution
Old 08-21-2014, 08:00 AM   #1
kyle_rivas's Avatar
Exhaust
Hi I just recently droped my 89 mustang of at a muffler shop and they were supposed to install my offroad xpipe no cats and my super 10s flowmasters and they called and said that they're not able to remove the cats from my car its illegal... I know it is but I still want them removed??? But I agreed to just keep the factory h-pipe with the cats and just put the super 10s on and dump them is that good? $60 in the future ima buy cats for my x-pipe and have them installed what kind of cats are best for off road x-pipe?
galaxy s4
kyle_rivas is offline   Reply With Quote
Old 08-21-2014, 09:38 AM   #2
Just swap the pipe yourself dude, it takes an hour tops from start to finish.
Old 08-21-2014, 10:26 AM   #3
kyle_rivas's Avatar
Its gonna be extremely hard do to that I have to use jack stands and I have to cut the mufflers off and weld them to the xpipe and im not sure how to do that
galaxy s4
Old 08-21-2014, 10:39 AM   #4
The way it is supposed to be is flow tubes from the mufflers which have ball/socket on them and those just bolt to the X pipe. You should NOT be welding your mufflers to the X pipe.
Pypes 2.5in Mustang Stainless Steel Replacement Flow Tube Kit PFF10K (79-04 V8, V6; 94-99 Cobra) - Free Shipping
Those clamp or weld to the mufflers then just attach with 4 bolts to the X pipe for easy removal/install. You can always cut the mufflers out and have the shop weld those flow tubes onto them and then DIY in the driveway. No need to have a shop install an X/H pipe, not if you have a basic socket set and jackstands.
Old 08-21-2014, 11:29 AM   #5
kyle_rivas's Avatar
Oh yes I know the 4 bolts that hook up to the headers right? Thats sorta simple so they are already doing is do you suggest that when I get some time I can just unbolt the hpipe and cut to mufflers off of it and weld them to my xpipe and just install it that simple?
galaxy s4
Old 08-21-2014, 11:49 AM   #6
No... those pipes do not go to the headers they go from the muffler to the mid pipe.
Here's a pic of mine, this is how they are supposed to attach. There is no welding on the mid pipe whatsoever.
Old 08-21-2014, 12:02 PM   #7
Adogg's Avatar
I think what he is saying is the muffler shop is going to do some welding??
Don't hate....... appreciate
Old 08-21-2014, 12:49 PM   #8
Then the muffler shop is a bunch of noobs. The last thing you want is a mid-pipe you can't drop if you ever have to do anything with the trans.
Old 08-21-2014, 01:02 PM   #9
Adogg's Avatar
lol yea that's the only reason for wielding I can think of
Old 08-21-2014, 01:06 PM   #10
kyle_rivas's Avatar
Wow my post didn't post
galaxy s4
Old 08-21-2014, 01:09 PM   #11
kyle_rivas's Avatar
Well I said I dont understand all this because they said the only thing they can do is hook up my 10s to the stock hpipe because I dont have cats on the xpipe and their gonna dump them after the mufflers and ge said it will still sound good hes not able to install my x due to the laws of the shop its illegal I just want it to sound good and I dont know much about installing mufflers
galaxy s4
Old 08-21-2014, 08:11 PM   #12
kyle_rivas's Avatar
Actually sounds great
galaxy s4
Old 08-22-2014, 05:55 AM   #13
galaxy s4
galaxy s4
The shop won't install your pipe because it is a federal crime in the USA to remove emissions equipment. No idea what all the talk of welding is but there should not be any welding required. Most likely, there is a miscommunication somewhere. Your exhaust should look similar to mine, just no tailpipes. This means that with a basic socket set and an hour of your time you can install the X pipe yourself. This is not rocket science and honestly, unless you've been paying someone else to do all the work on your car, there is 0 reason you can't do it. Again, if someone welded your mufflers to the stock H pipe, they should be shot but I doubt this is the case.
Old 08-22-2014, 11:27 AM   #14
kyle_rivas's Avatar
This is what it looks like
galaxy s4
Old 08-22-2014, 11:37 AM   #15
galaxy s4
Well that's good, they hacked up your stock H... wow... Now your mid pipe is completely not removable unless you cut it where they welded or remove the rear axle. I'd take it back and make them do it right if it were me.
Old 08-22-2014, 01:40 PM   #16
kyle_rivas's Avatar
Is it to late to do my xpipe? I have a grinder and I know how to weld
galaxy s4
---------- Post added at 07:40 PM ---------- Previous post was at 07:39 PM ----------
And its not as loud as I thought it would be
galaxy s4
Old 08-23-2014, 06:37 AM   #17
foxbox's Avatar
Exhaust
Nothing about that even looks right man. I wouldn't of left the shop with the exhaust looking that way. I understand that you didn't even know what it was suppose to look right in the first place do you were kinda screwed from the beginning. After reading a couple of your threads, it appears you jump it your project with little or no research. Do yourself favor and do the research before you jump into the next step of your project. Do I mean read several books and draw up a Gantt chart?, no. Simply know what you are getting into. For example, for your exhaust. All you would have done was to go on AM or late model and look at the different components of the exhaust or the tip guides they have to understand how the exhaust system fits together. Research will save you a lot of time, money, and headache. This is advice everyone could use so don't take it personally.
foxbox is offline   Reply With Quote
Old 08-24-2014, 12:02 AM   #18
This x1000. Any POSSIBLE question one can ever think to ask about a fox body mustang has already been discussed ad-nauseum across multiple mustang forums.
Old 08-24-2014, 07:39 AM   #19
99_GRUMPY_GT's Avatar
Make that x 10,000.
OP, if it were me, I would of already had my butt back to that shop and had them fix what they f*c*ed up. Whoever did that should not be in the position to do exhaust work.
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 08-25-2014, 12:23 AM   #20
kyle_rivas's Avatar
Its really not a big deal guys im satisfied for now ill just do it later on
galaxy s4
Old 08-25-2014, 07:19 AM   #21
galaxy s4
That is not the point we all were trying to make here. All mustang exhaust systems bought are primarily bolt on sytems, from mid pipes, h-pipes, x-pipes, and mufflers, and tailpipes. This being said, your system is no longer bolt on application, now or never as the person that hacked your exhaust up has made sure of that. Now you are stuck having to cut and weld unless you replace the whole system from header flange to tailpipes.
But since you state it is no big deal and you are satisfied, so be it. But if you keep that frame of mind in the future, you will have a rough road ahead of you when the time comes for repairs.
If for whatever reason you have to drop your transmission for a repair, you are now stuck with having to disconnect your header flange and cutting your exhaust to get the trans out, instead of unbolting your system. See where I am coming from?
Old 08-25-2014, 05:27 PM   #22
kyle_rivas's Avatar
Ya I understand but i dont get the hole bolt on concept because before the h-pipe to the mufflers never had a bolt on it was always cats then h then weld on nd yes I get you but I dont get how mufflers bolt on to my x-pipe? It dosent have a place to bold onto like where the mufflers connect theres like a rounded tip and the mufflers didn't fit around and the mufflers didn't have a place to hook up
galaxy s4
Old 08-26-2014, 09:16 AM   #23
Your exhaust is supposed to look like the pic I posted in post #6 dude. The setup is 99% identical between the foxes and various SN95s. In post #4 I provided a link to the flow tubes that attach to mufflers to allow them to bolt onto the mid pipe. Do you even read?
I'm not quite sure what exactly you are not understanding.
Old 08-26-2014, 12:19 PM   #24
kyle_rivas's Avatar
Going back now and actually clicking the link I understand now I didn't have internet now so I can weld my mufflers to that pipe that bolts onto the X pipe.
galaxy s4
Old 08-26-2014, 12:55 PM   #25
You can just clamp them. I've installed plenty of catbacks and never even touched a welder.
Old 08-26-2014, 02:32 PM   #26
That is what I was trying to get this guy to understand. And I too have done plenty of my own exhaust set-ups and I too never used a welder to do so. I have in the past welded some systems, but that was by design, not by a so called exhaust guy screwing up someones set-up all to hell.
Old 08-26-2014, 03:59 PM   #27
kyle_rivas's Avatar
Ok so if I get what you said on post #4 do I weld my mufflers to the piece ima order
galaxy s4
Old 08-26-2014, 04:15 PM   #28
galaxy s4
NO! Get the welding out of your mind. I do not know why with every post you make in this thread you mention welding. NO WELDING! If you bothered to look at the pics supplied on that link that Scotty provided you, you would see that the pipes bolt onto the flange of the x or h-pipe, then the straight portion slides into the muffler inlet and clamps on.
Old 08-26-2014, 04:38 PM   #29
kyle_rivas's Avatar
I understand but I dont see how the mufflers hook up here I dont see any clamps...
galaxy s4
Old 08-26-2014, 05:25 PM   #30
Look at the pic, in this example they are using band clamps which in my opinion are the best type of clamp. The band clamp has a tar bead that is applied to the inside portion of the clamp, when tightened down it spreads all around the pipe to seal from leaks.
Click on pic to enlarge.
Old 08-26-2014, 05:44 PM   #31
kyle_rivas's Avatar
Where can I get band clamps
galaxy s4
Old 08-26-2014, 06:10 PM   #32
When I do my exhausts, I always in the past got mine from Summit Racing. They are under the exhaust catagory and come in different sizes. But you probably can get them locally or other online sources. The best part about band clamps are that you do not have that struggle to seperate your exhaust components as you do when you use regular exhaust clamps. As a regular clamp crimps the pipe to the muffler, and usually requires heat to seperate if you are lucky. As a band clamp holds both ends of the pipe as a butt clamp and the pipes do not go inside the other, but butts up to one another. When you click on the click I supplied you below, click on the video under the pic of the band clamp, and it explainss the exhaust and band clamp and how they work.
http://www.summitracing.com/parts/sum-692250/overview/
Old 08-26-2014, 06:25 PM   #33
kyle_rivas's Avatar
Thanks so much man I will buy the parts Friday and install them when I get it
galaxy s4
Old 08-26-2014, 07:08 PM   #34
Just remember that the band clamps come in 2 different forms, you can butt clamp the pipes, meaning both pipes to be mated together are the same overall diameter, or if you have a male and female pipe meaning that one slides into the other, then there is a band clamp for that also, one side of the clamp is smaller than the other side of the clamp. Both were explained in that video I told you to click on Summit's link I supplied. So just make sure you get the right ones for your application.
Old 08-26-2014, 07:14 PM   #35
kyle_rivas's Avatar
Why is it rounded and sir I didn't really understand what you ment
galaxy s4
exhaust
Exhaust is driving me crazy, cant find much on exhaust for 67 Joshy Classic Mustangs 27 02-05-2014 06:26 PM
Exhaust is driving me crazy, cant find much on exhaust for 67 Joshy Classic Mustangs 0 01-11-2014 06:54 PM
One exhaust tip a little off after Boss exhaust install mmike87 2011-2014 Mustang GT 6 09-21-2012 07:42 PM
New Exhaust Video......3'' Exhaust WaldoGT07 General Mustang Discussion 0 12-20-2011 07:59 PM
» Members Mustangs
My car
Boostr
Boss
shoofey
Add your Mustang
12:58 PM
