1988 ford 5.0 mustang lx/gt 5 speed fuel pump relay or ecm or wire? - Mustang Evolution
Old 08-28-2014, 09:55 AM   #1
mryoung4815's Avatar
I let my car sit for 2 weeks then start it up and I drive to the gas station about a mile away no problem ran fine. Turned the car off payed for gas turn the key after fueling and no noise from the fuel pump so I towed it home tried to find the inertia switch and it seems the previous owner bypassed the switch it's not in any of the locations whatsoever. So I purchased a new fuel relay part number 913157 and disconnected the batt hooked up the new one and turned the key and now the fuel pump stays on non stop and still no start just cranks doesn't catch at all so then today I put the old relay back in and it does the same thing stays on so with the pump on I went to the EEC test box under the hood with a test light stuck the needle into the far right and bottom pin and the fuel pump turns off but still no start so then I find the a9 CPU and it looks to be fairly new or reman in 2001 from what the print says any ideas? I recently changed the*spark*plugs*and wires and cap and rotor and noticed one of the plugs on the left side of the engine was burned a little by being to close to the header could this be an issue ? Any help would be appreciated
Sent from my SCH-I415 using Mustang Evolution mobile app
mryoung4815 is offline   Reply With Quote
Old 08-29-2014, 06:07 PM   #2
DK Racing's Avatar
I have just had similar issues with my 87 I converted it to the MAF {A9L} computer and the same things were happening I replaced several parts but a new box has it running again found a company on ebay with a life time warranty for $300 minus a $50 core very frustrating to fix but I hope this helps.
DK Racing is offline   Reply With Quote
Pink/black fuel pump relay wire Shifty 5.0 1979-1995 Mustang GT 2 07-29-2014 08:07 PM
I need help replacing my fuel pump relay in my 1986 Mustang LX? ashbbie 1979-1995 Mustang GT 2 12-15-2011 05:50 PM
Fuel pump relay Jamesgt08 1996-2004 Mustang GT 13 03-12-2011 03:13 PM
ECM Wiring Relay for a 1983 Mustang 5.0? gillecriosd General Mustang Discussion 2 04-06-2010 02:04 PM
Location of ccrm and fuel pump relay on 1997 mustang v6? emrys27 Pre-2005 V6 Mustang 3 08-24-2009 03:09 PM
09:51 AM
