1990 mustang t5 transmission problems - Page 2 - Mustang Evolution
Old 09-03-2014, 08:08 AM   #36
Stock clutch will be fine. Camming a stock headed motor is going to do literally nothing but change the idle and powerband. You need to swap the heads to get any sort of appreciable power gain.
Old 09-03-2014, 08:10 AM   #37
Amanhi9's Avatar
See idk if those r stock heads or not so idk wat all they have done
Amanhi9 is offline   Reply With Quote
Old 09-03-2014, 08:30 AM   #38
99_GRUMPY_GT's Avatar
There should be a stamping on the head and that will tell you if they are stock or not? Also if they were reworked internally, then the only way to tell that would be to take the valve cover off to look at the rockers and springs.
But for argument sakes, lets just assume they are stock, the stock OEM clutch would be the perfect clutch for your application, as mentioned before, what you have named off as being done to engine and or transmission is not a factor to upgrading your clutch.
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
1990 mustang
1990 mustang 5.0 transmission upgrade question? T-5 or Tremec TKO 600 extra HD? bitten 1979-1995 Mustang GT 1 12-23-2011 03:16 AM
What is that plate on a 1990 Mustang 5.0 transmission that guards the flywheel? taurino 1979-1995 Mustang GT 1 12-20-2011 01:59 PM
Can you change a manual transmission to an automatic transmission 2007 mustang? Ekon General Mustang Discussion 3 12-18-2011 03:09 AM
1990 Mustang 5.0 EGR Problems? riki 1979-1995 Mustang GT 1 12-15-2011 04:52 PM
02 Mustang Possible Transmission Problems TK225 General Mustang Discussion 3 10-07-2008 06:41 AM
10:29 AM
