1990 mustang t5 transmission problems - Mustang Evolution
Old 08-29-2014, 03:02 PM   #1
Amanhi9's Avatar
i just bought the car had to put a rear end in it when i went to drive it wont go into 2nd unless i slam it and most the time that dont work and it grinds going into 4th my question is what could that be all the other gears are fine the guy said he had to tighten down the pilot bearing i think it was all the way down or out because he didnt have a pedal and also when i shift it feels like the clutch isnt releasing from the motor i just need help plz
Amanhi9 is offline   Reply With Quote
Old 08-29-2014, 04:22 PM   #2
FordRacer_51's Avatar
If it was the clutch It'd do it in all the gears not just second and forth
FordRacer_51 is offline   Reply With Quote
Old 08-29-2014, 04:24 PM   #3
Amanhi9's Avatar
The clutch flywheel pilot bearing and pressure plate are all new
Old 08-29-2014, 04:26 PM   #4
Amanhi9's Avatar
What do u think it could be because he said he had to tighten the pilot bearing all the way out
Old 08-30-2014, 06:25 AM   #5
Infantry09's Avatar
Shift forks are bad... Maybe
Infantry09 is offline   Reply With Quote
Old 08-30-2014, 06:26 AM   #6
Amanhi9's Avatar
We'll I can start it out in 2nd fine but it's when I go from 1st to 2nd
Old 08-30-2014, 06:46 AM   #7
foxbox's Avatar
Had sorta the same issue one time and it turned out that my pressure plate flew apart. As a result the clutch would not disengage because shrapnel was wedged between the clutch and pressure plate. Honestly I would just buy a fresh new clutch kit, change fluid, and start from there.
I don't always reply but when I do, it's helpful
foxbox is offline   Reply With Quote
Old 08-30-2014, 06:47 AM   #8
Amanhi9's Avatar
We'll the clutch flywheel and pilot bearing and pressure plate are all new
Old 08-30-2014, 07:12 AM   #9
I had the same issue as fox box and it was a brand new ram hdx clutch with less than 500 miles on it.
Old 08-30-2014, 07:14 AM   #10
Amanhi9's Avatar
Oh dang yea hopefully I can get it figured out and be able to drive it
Old 08-30-2014, 07:39 AM   #11
This sounds like a synchro issue.
Sent from my EVO using Mustang Evolution mobile app
Colorado Corey is offline   Reply With Quote
Old 08-30-2014, 07:45 AM   #12
I would lean more toward a synchro issue
Old 08-30-2014, 07:46 AM   #13
Amanhi9's Avatar
Wat is invoked in fixing that?
Old 08-30-2014, 07:49 AM   #14
Taking the trans apart and rebuilding it.
Old 08-30-2014, 07:50 AM   #15
Amanhi9's Avatar
Oh joy
Old 09-02-2014, 11:18 AM   #16
Time for a new trans. Also there is no tightening a pilot bearing, he was probably talking about the throwout bearing and it should not be tightened all the way down, it should be set so there is a solid tension on the cable but not too much or too little.
Honestly someone who was telling you "pilot had to be tightened down" is completely clueless and I would not really believe anything else he or she told you about the car. The good news is, T-5s are a dime a dozen and are very easy to change out. At 75lbs its not even that hard to do yourself if you can't get anyone else to help.
Old 09-02-2014, 11:35 AM   #17
Agreed. The pilot bearing is not adjustable at all. The input Shaft just rides in it. So yea either new trans or a rebuild
Old 09-02-2014, 11:40 AM   #18
99_GRUMPY_GT's Avatar
+1
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 09-02-2014, 11:57 AM   #19
Amanhi9's Avatar
I had meant throw out bearing but write the wrong thing well I found out that the clutch cable where it connects to the transmission they had 4 nuts on it I guess because it was to long so I changed the whole clutch cable well now I have a better clutch pedal but still won't go into second so I have a manual 4 speed I think I'm gonna switch it out with
---------- Post added at 11:57 AM ---------- Previous post was at 11:56 AM ----------
And the 4 speed is out of a 83 body style that had a 5.0 in it I hope it will bolt up
Old 09-02-2014, 11:59 AM   #20
I would not even think to do that.
Old 09-02-2014, 12:00 PM   #21
Amanhi9's Avatar
Wat u mean?
Old 09-02-2014, 12:16 PM   #22
The SROD (Single-Rail Overdrive)4 speed as it was called was not used in anything other than a fully restored mustang as that was original equiptment. The reason was the SROD could not handle higher HP gains and therefore was ditched in favor of the T-5. The SROD was a terrible transmission. And by you putting that in your car is down grading for what is already in there. Just get the T-5 repaired and don't look back. Or go and swap a T-5 for that one. They are a dime a dozen these days, just make sure you get a 89-90 model and not a 87-88 if you do the swap. You may want to take it to a transmission shop just to have it looked at for free at most shops. And go from there.
1983-1989 Mustang T5 was equipped with a yellow 7-tooth speedometer drive gear and 1990-1995 Mustang T5 was equipped with a light green 8-tooth drive gear. Not to mention the input shaft and output shaft are different.
Seriously, it is not your best option to do that.
Old 09-02-2014, 12:18 PM   #23
1- it likely won't fit. 2- its going to be much weaker. 3- you'll lose overdrive.
Bad idea no matter how you cut it, get on some forum classifieds and look for a good used world class T-5 and see what's around.
Also figure out your cable setup. You should ONLY be using an OEM cable, if you are using a parts store cable then get rid of it.
Old 09-02-2014, 12:19 PM   #24
Amanhi9's Avatar
The cable was a parts store cable we just got rid of it and put the one off the 83 on it and it worked fine
Old 09-02-2014, 12:19 PM   #25
Here is a webpage I saved for future use when it came to Ford Mustang transmissions. Read it and see why. I pasted soem of the info in the previous response. But You will understand by reading it all.
What Manual Transmission is in My Mustang?
Old 09-02-2014, 12:25 PM   #26
Amanhi9's Avatar
Thanks I think we're just gonna leave the t5 in it and rebuild it when we get the money
Old 09-02-2014, 12:35 PM   #27
Amanhi9's Avatar
What do u think about running a stock clutch behind a carbed and camed 302
Old 09-02-2014, 12:38 PM   #28
Smart move, or like I said, find a working T-5 and swap it. Probably cheaper than a rebuild.
Old 09-02-2014, 12:55 PM   #29
Amanhi9's Avatar
Old 09-02-2014, 12:58 PM   #30
Right back at ya
Old 09-02-2014, 01:03 PM   #31
Amanhi9's Avatar
Old 09-02-2014, 01:13 PM   #32
Depends, a stock clutch is rated to HP capability as any part is. What kind of HP is this carb'd & cammed 302 putting out? I would think it is ok to use the stock clutch as igf that is the only thing done to this engine you speak of, then go ahead and use it. I was confused as to your ? as you had jumped to couple different directions in this thread.
Old 09-02-2014, 01:16 PM   #33
Amanhi9's Avatar
It's a e303 cam profound 650 carb edelbrock performer 289 intake
Old 09-02-2014, 01:21 PM   #34
I keep archives in my favorites or files as to help others understand the questions they are asking. Here is a webpage for you to read to understand better the question you just asked. I find it very useful to provide facts as written vs unwarranted info. So these sites of information is for all of our benefits and not just mine. And I find it easier to understand vs me trying to type it so you understand it too.
Choosing the Correct Clutch for Your Mustang
Old 09-02-2014, 01:23 PM   #35
Amanhi9's Avatar
Proform carb sorry
1990 mustang
1990 mustang 5.0 transmission upgrade question? T-5 or Tremec TKO 600 extra HD? bitten 1979-1995 Mustang GT 1 12-23-2011 03:16 AM
What is that plate on a 1990 Mustang 5.0 transmission that guards the flywheel? taurino 1979-1995 Mustang GT 1 12-20-2011 01:59 PM
Can you change a manual transmission to an automatic transmission 2007 mustang? Ekon General Mustang Discussion 3 12-18-2011 03:09 AM
1990 Mustang 5.0 EGR Problems? riki 1979-1995 Mustang GT 1 12-15-2011 04:52 PM
02 Mustang Possible Transmission Problems TK225 General Mustang Discussion 3 10-07-2008 06:41 AM
06:10 PM
