Hesitating while accelerating - Mustang Evolution
Old 08-31-2014, 07:54 PM   #1
jac142192's Avatar
What would cause this almost seems like its not getting enough gas. Could be a stupid question but just want to get some ideas before I start replacing things. Its a 100% stock 351w with stock 2 barrel carb from a 1979 van.
Sent from my SCH-I535 using Mustang Evolution mobile app
jac142192 is offline   Reply With Quote
Old 08-31-2014, 08:16 PM   #2
99_GRUMPY_GT's Avatar
I am assuming by you posting here that you have a foxbody mustang. And having a 351w out of a van, ugghhh! If you are experiencing slow take off then you may want to look at the fuel filter, air filter, fouled spark plug(s), or improper spark plugs, bad spark plug wire. Or it might be brecause it is out of a van, I would assume the valve train is setup for torque and not HP since it is designed to tote not smoke.
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 08-31-2014, 08:39 PM   #3
jac142192's Avatar
Ok thanks for the suggestions yup its a fox sorry for not mentioning that just picked it up for $800
Old 08-31-2014, 08:40 PM   #4
jac142192's Avatar
Many different colors lol
Old 08-31-2014, 09:07 PM   #5
By the way welcome to the forum.
Also check the ditributor cap and rotor. I was not trying to make fun or your engine, just joking around with you. But it is an engine setup for cargo and not performance though if nothing has been done to it. What year motor is it, and have you or anyone done anything to it, performance wise? Foxbodies are my first love, besides a 67 fastback.
Old 08-31-2014, 11:35 PM   #6
jac142192's Avatar
Thanks and no the guy I bought it from as I it was a straight pull and put it in. Still has the smog pump and emission stuff. Its a 1979 motor.
ID:	164907   Click image for larger version
Old 11-07-2014, 11:13 PM   #7
If your fuel line is close to engine or exhaust and exposed to heat could be vapor locking. I solved problem by shielding fuel pump and wrapping lines with foil tape
85fox is offline   Reply With Quote
Hesitating Tangtang2.0 1996-2004 Mustang GT 2 04-13-2014 08:39 AM
Car Stumbling/Hesitating v8pony 1996-2004 Mustang GT 8 03-11-2014 04:35 PM
Weird rattling while accelerating at around 1200-1500 rpms. Veracadoro Pre-2005 V6 Mustang 21 02-14-2014 05:01 PM
1987 mustang 5.0 misfiring while accelerating? ethan 1979-1995 Mustang GT 5 12-23-2011 01:06 AM
e-brake light turns on while accelerating 1997grnstang Pre-2005 V6 Mustang 6 10-22-2006 12:31 PM
09:32 PM
