Surging Idle, stalling, and fuel pump - Mustang Evolution
Old 08-31-2014, 10:39 PM   #1
I have been having alot of idle issues with my fox body lately. It started right after i installed a 70mm throttle body and egr sensor. My cars idle was all over the place and it would stall at every stop. I adjusted the egr sensor and it helped a little but it would still stall. Then I installed a 255lph fuel pump and the problem got even worse. The idle would surge the moment i start the car and alot of the time it would just shut off. Sometimes it wont start so id have to turn off the fuel pump and then start it. I dont know if its to much fuel since all i have done to my car is exhaust, throttle, and cold air. Do I need a tune to fix this? Any help would be apreciated.
Sent from my SM-N9005 using Mustang Evolution mobile app
Alex5123 is offline   Reply With Quote
Old 08-31-2014, 11:16 PM   #2
I wasn't aware that it's possible to adjust the EGR sensor. Do you mean the Throttle Position Sensor?
Anyway, I think that you probably need to adjust the throttle body.
Will the engine run normally if you have your foot on the accelerator and are giving it some "gas"?
Old 09-01-2014, 01:05 AM   #3
Yea sorry i mean the throttle position. Yes the car runs fine while im giving it gas and i did not notice any drop in power or hesistation only the idle
Old 09-01-2014, 01:15 AM   #4
Yeah, apparently you have to adjust the throttle plates with the set screw on the aftermarket throttle bodies. They need to be set so that a little bit of air flows through when the plates are "closed".
There is a link to how to properly adjust a throttle body in one of our members recent posts... cliffyk. If you can't find cliffyk's link with a search, the information is probably online somewhere if you Google it.
Old 09-01-2014, 07:13 AM   #5
Liebert91stang's Avatar
I would also check the fuel pressure since you put new fuel pump in.
Liebert91stang is offline   Reply With Quote
Idle and surging problems. 94 GT 5.0 SVT Mustang 0 09-08-2013 12:16 PM
Infamous surging idle Meansaleen 1979-1995 Mustang GT 12 08-21-2011 07:35 AM
Surging idle Albaraptor 1979-1995 Mustang GT 4 02-16-2011 11:27 AM
Surging idle Keto77 1996-2004 Mustang GT 3 08-15-2009 09:36 AM
rough/surging idle dragonlouie 1979-1995 Mustang GT 25 08-23-2008 07:59 PM
04:27 PM
