Power window probs - Mustang Evolution
Old 09-03-2014, 08:25 AM   #1
ThatAdamsBoy69's Avatar
Power window probs
My 1990 gt driver side power window has stopped working every time I hit the switch my volt gauge says that I'm losing power however my window does not go down my passenger window and my two other windows go down (convertible) with no problem I need direction on what I should or if someone had a common prob and fixed oh and apparently the window motor has been replaced
ThatAdamsBoy69 is offline   Reply With Quote
Old 09-03-2014, 08:27 AM   #2
99_GRUMPY_GT's Avatar
Do you hear a clicking noise from the dash area or door when you press the rocker switch for the bad window?
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 09-03-2014, 08:32 AM   #3
Nope
Old 09-03-2014, 08:35 AM   #4
Strange Mud's Avatar
If it's dropping voltage I'll guess bad motor/gear box or short.
Old 09-03-2014, 08:35 AM   #5
Do you have a multi-meter to check if you are getting voltage to the switch in question? If so, check that, if you are getting voltage, then I would then check if you are getting voltage to window motor, if you are, then the motor would be subject. If not, then the switch is subject. The motors are suspect alot of times as the gear at the motor is plastic, and wears out. But any auto store sells a repair kit to replace the gears. But first we need to know if it is the motor or the switch first.
Old 09-03-2014, 09:58 AM   #6
While I was working on it, it made a clicking noise inside the door pannel when I hit the switch
Cam probs, need advice!! WhiteCobra94 1979-1995 Mustang GT 7 03-11-2011 07:57 PM
Underdrive pulley causing steering probs? Otlaw80 1979-1995 Mustang GT 3 06-16-2009 07:14 AM
94 GT New engine, now have weird Electrical Probs... Ideas? keebler117 1979-1995 Mustang GT 2 12-11-2007 03:43 PM
side exhaust probs powerhungry966 Pre-2005 V6 Mustang 8 09-15-2005 03:09 AM
mach 460 probs 99CobraVert Mustang Audio & Video 3 08-19-2005 02:07 PM
07:00 AM
