Rocker arm adjustment - Mustang Evolution
Old 09-03-2014, 05:06 PM   #1
Shifty 5.0's Avatar
So after my build and driving it's time to readjust the roller rocker arms because they are starting to make noise. Any special way to go about doing this? Or just do it the same as I did when I put it together the first time? Iv seen people do it with the car running and what not and was just wondering what the best way to go about doing it is.
Shifty 5.0 is offline   Reply With Quote
Old 09-04-2014, 08:53 PM   #2
You gots pedestal or stud mounted? Pedestal is a pain in the nuts. Stud is really easy.
Old 09-04-2014, 10:31 PM   #3
Shifty 5.0's Avatar
Mine are just the comp cams stamped steel magnum roller rockers.Click image for larger version
Name:	ImageUploadedByMustang Evolution1409891469.053211.jpg
Old 09-05-2014, 12:33 AM   #4
If you have hydraulic lifters and the rocker arms were adjusted properly when they were installed, you should never have to adjust them.
It's solid lifters that need frequent adjustment.
I NEVER adjust hydraulic lifter equipped engines while they are running. Do it with the engine off and rotate it by hand for each cylinder.
There are tons of YT vids and all of the pushrod V8's use the same method.
Old 09-05-2014, 07:43 AM   #5
Shifty 5.0's Avatar
Yeah I'm just going to check to see if any are loose and then do it the same way I did it when I built it. Seems like the best thing to do
Old 09-05-2014, 10:26 AM   #6
So again... pedestal or stud?
Sent from my VS980 4G using Mustang Evolution mobile app
Old 09-05-2014, 10:30 AM   #7
The picture of the rocker arms that he posted look like stud mount.
Old 09-05-2014, 01:38 PM   #8
Shifty 5.0's Avatar
Yeah they're stud mount
Old 09-05-2014, 09:16 PM   #9
With the motor off and the pushrod on the base of the cam lobe, tighten down the rocker arm with one hand while you are actively spinning the pushrod for that rocker arm in the other. When the pushrod gets to zero lash (you can't easily spin it anymore) go 1/4 turn further and you are done with that rocker, move onto the next one and rotate the crank accordingly to make sure each one is on the base of the cam when you do it.
Old 09-05-2014, 09:17 PM   #10
Shifty 5.0's Avatar
Yeah that's the way I did it when I built it. Can I do it no matter the temp of the motor?
Old 09-05-2014, 09:25 PM   #11
Not sure why or even how you'd do it on a hot motor by the time you got the VCs off and burned the **** out of your hands.
Old 09-05-2014, 09:29 PM   #12
Shifty 5.0's Avatar
Old 09-28-2014, 03:38 PM   #13
U can do it hot or cold. It's dumb to do it after a long drive but hey. Your hands not mine.
Tasteslikeink is offline   Reply With Quote
Rocker arms adjustment fordtough1991 1979-1995 Mustang GT 1 05-06-2013 11:33 PM
Rocker arm stud conversion kit! WhiteCobra94 1979-1995 Mustang GT 1 12-15-2011 04:44 PM
Rocker arm question? WhiteCobra94 1979-1995 Mustang GT 7 09-12-2011 12:46 PM
Adjustable crane cam rocker arm problems ballajb 1979-1995 Mustang GT 8 11-04-2009 09:30 AM
rocker arm help rbhasychak 1979-1995 Mustang GT 4 08-14-2007 05:04 PM
04:19 AM
