Mustang acceleration problems - Mustang Evolution
Old 09-04-2014, 11:22 AM   #1
SkylerTallman_'s Avatar
Hey guys, I'm having trouble with my 94 5.0. It will accelerate very slowly and will stall itself even at high speeds occasionally when I depress the clutch. The thing is that if I'm at a half tank of gas, it will accelerate fine and pull pretty hard. Could it be spark plugs? Maf sensor? And it also won't pull hard when it's cold at all, even when I do have a half tank. And my fuel pump was checked and it's reading 39lbs so that shouldn't be the problem. Thanks
SkylerTallman_ is offline   Reply With Quote
Old 09-04-2014, 12:16 PM   #2
kyle_rivas's Avatar
Get a tune up before doing anything
instagram @5.0_rivas
kyle_rivas is offline   Reply With Quote
Old 09-04-2014, 12:17 PM   #3
Sorry I didn't include that but I did do a full tune up and it helped but not near to what it should be running at.
Old 09-04-2014, 12:25 PM   #4
natestang07's Avatar
Yep clean up your maf and take a look at your plugs. Has it been awhile since they were changed?
05 Gt Premium Performance White, flowmaster outlaws
Old 09-04-2014, 12:33 PM   #5
Cleaned my maf and changed plugs and wires during tune up.
Old 09-04-2014, 12:38 PM   #6
Does it feel like there is slack in the pedal kind of?
---------- Post added at 11:38 AM ---------- Previous post was at 11:37 AM ----------
And how did the plugs look by the way? Any discoloration on them?
Old 09-04-2014, 12:40 PM   #7
Not really but I floor it, and it doesn't speed up, it just revs slowly. And I didn't notice. Will then be gapped wrong do this.?
Old 09-04-2014, 12:45 PM   #8
Possibly but I'm a little skeptical on that. Fuel filter changed or no?
Old 09-04-2014, 12:46 PM   #9
Yes sir, changed the fuel filter and fuel pump read 39lbs so didn't change it
Old 09-04-2014, 12:49 PM   #10
http://www.ehow.com/facts_4881478_sy...gs.html#page=6
read through that real quick and see how much of it is related to you if any
Old 09-04-2014, 12:52 PM   #11
Everything but the knocking. The spark plugs are around 3 months old. Should I just take them out and check and fix the gap or buy new ones?
Old 09-04-2014, 12:54 PM   #12
99_GRUMPY_GT's Avatar
Have you checked your TPS (Throttle Position Sensor)?
And is there any codes, check engine light (CEL)? And if so what are they?
And what kind of plugs did you put in the car? And what gap?
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 09-04-2014, 12:56 PM   #13
No I haven't checked that. And it's throwing codes, my mechanic told me while he did work on it awhile back but said he doesn't know much about sn95's and couldn't figure out what they codes meant
Old 09-04-2014, 12:56 PM   #14
^ he can help a lot more than me. He seems rather knowledgeable
Old 09-04-2014, 12:57 PM   #15
And the plugs were motorcraft
Old 09-04-2014, 12:58 PM   #16
Do you remember what the codes were?
Old 09-04-2014, 01:00 PM   #17
He didn't tell me the codes. He just told me his buddy could put it on his dyno and can mess around with it because his buddy specializes in sn95's. But of course for a couple hundred dollars
Old 09-04-2014, 01:02 PM   #18
You should get the codes from somewhere. Autozone does it for free but not sire if they could do it for you because I assume you have an obdI
Old 09-04-2014, 01:04 PM   #19
Yea I can't. Unfortunately I cant use the hand held scanners
Old 09-04-2014, 01:09 PM   #20
Are you still showing a CEL now? And if so do you have a scan tool to pull the codes? If not then you can go to any Autozone or Advance Auto and have them pull the codes for free. I would like to know what they are as that is the key to all this most likely. And the first place I would want to look is at the TPS. And you can check the TPS yourself with a voltage meter.
You can test the TPS with a volt meter, preferably a anolog meter as you can visually see the rise in voltage better than a digital meter. Measure it's output voltage ~1V with the throttle closed, (V output)=(V reference) with it open (~5V).
If you are going to test it, take the voltage meter and test i9t throughout the range of the throttle body operation...
You want to see a nice smooth increase in voltage...you don't want to see an increase to a certain voltage, then a plateau, and then another increase...TPS are known to develop those dead spots.
Old 09-04-2014, 01:10 PM   #21
The check engine light goes on and off randomly.
Old 09-04-2014, 01:11 PM   #22
That is not true, OBDI systems can be read by a scanner, it is a analog scanner that has a red blinker on it to read out the code format for each code and Autozone and Advance do have them. You plug it up to your test port in the engine bay near the D/S firewall.
Here is a picture of one.
Old 09-04-2014, 01:13 PM   #23
That is good then, now we can get the codes to see what it is telling you.
Old 09-04-2014, 01:13 PM   #24
Attachment 165171
I went to my local advance auto a couple weeks back and they wouldn't do it. They denied me. Can I buy one from advance auto and read them myself
Old 09-04-2014, 01:18 PM   #25
Yes, that is what I meant. The OBDI scanners are cheap because they are analog. But the book supplied with the scanner will tell you how to interpret the series of blinks the red light makes, it will read out one series of blinks, then a quick break and then a second series of blinks, and so on to the next codes, then it will repeat itself once all the codes have been read. I keep one handy at home along with my OBDII scanner as my neighbor and others are running OBDI systems.
Old 09-04-2014, 01:19 PM   #26
How much are one of these? Like how cheap?
Old 09-04-2014, 01:24 PM   #27
Here it is at autozone
Actron/OBD I code scanner (CP9015) | Code Reader | AutoZone.com_
Old 09-04-2014, 01:34 PM   #28
On my way to autozone to get one. Get back to the thread later with the codes
Old 09-04-2014, 01:45 PM   #29
That is what I am talking about, action causes reaction. If you have any problems with the CEL codes, just chime in.
Old 09-04-2014, 01:59 PM   #30
This is the right one? Just to be 100% positive before I open itClick image for larger version
Name:	ImageUploadedByMustang Evolution1409860780.772192.jpg
Old 09-04-2014, 02:06 PM   #31
Boy, you are fast. You must live nest door to Autozone. Yep the same one as I got. I even supplied a pic of mine for you to compare.
Old 09-04-2014, 03:34 PM   #32
Hey man, I can't get it to work. It's plugged in and I'm following the steps so I think. The device turns on and just will continually beep. No pauses on anything. Click image for larger version
Name:	ImageUploadedByMustang Evolution1409866434.493660.jpg
Old 09-04-2014, 03:42 PM   #33
You don't need a scanner, you can use the check engine light to pull the codes. Google the procedure. You basically just jumper the OBD1 port with a paper clip or whatever and the CEL will blink your your codes. Example, if it was 585 (no idea if that is a real code) it would be 5 blinks, pause, 8 blinks, pause, 5 blinks.
Also, just because you are reading 39lbs at idle doesn't mean its not the pump.
Old 09-04-2014, 04:12 PM   #34
The truck that I recently purchased has the same intermittent CEL. I read the code using the "jumper" method and it's the EGR valve. That doesn't necessarily mean that's the problem with you car.
You need to retrieve that code for us to be able to help you. We could sit around and guess at what your problem is all day long...
Old 09-04-2014, 04:16 PM   #35
Did you plug the scanner up with the key off, then put the scanner to hold position? Then once the scanner is placed on hold, go and turn the key to the on position without starting, then go to scanner and switch it to test?
Acceleration Problems NhFireSlayer Pre-2005 V6 Mustang 10 10-12-2013 10:55 PM
Ford Acceleration Problems TAG The Bar 37 09-03-2013 05:51 PM
Can a fuel filter cause acceleration problems. lemons95 Pre-2005 V6 Mustang 2 08-30-2013 04:46 AM
acceleration problems blk99stang Pre-2005 V6 Mustang 3 04-02-2006 01:32 PM
07:50 AM
