A hack owned my car :( - Mustang Evolution
Old 09-06-2014, 03:28 PM   #1
67mustang97's Avatar
Region: Vermont
I picked up a 89 5.0 lx a while ago and recently decided to upgrade the bargain basement cd player. A butcher must have owned my car because every wire in the dash had been cut, spliced and additional wires added for no apparent reason. So I took out my meter and started checking wires and found out my windows work with the key off along with my mirrors. Anyone have any ideas what I should do I really don't want to replace the harness if I can help it.
Old 09-06-2014, 03:33 PM   #2
do your windows/mirrors only work with your car off?
TurboCobra is offline   Reply With Quote
Old 09-06-2014, 08:50 PM   #3
99_GRUMPY_GT's Avatar
Well apparently someone spliced the window and whatever else and hooked it to a constant hot. Need to go trace the mini harness coming out of the door into the fenderwell leading to the fuse box and reroute those wires back to the original fuse location. You will not have to buy a new harness, just splice correctly and wiring it back to the fuse box and to the correct fuse. Either that or your ignition switch if broken and stays hot at all times.
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 09-07-2014, 07:33 AM   #4
Region: Vermont
Thanks for the ignition idea I'll pull one out of a parts car and see if that works.
Old 09-08-2014, 09:48 AM   #5
Welcome to the wonderful wonderful world of buying a used modded foxbody. Dude probably didn't want to have to have the key in to work the windows and went nuts with some butt splices. I'd see about getting a new harness and replacing the whole thing if you plan to keep the car.
How about listing Every car you ever owned ronnie948 The Bar 180 11-23-2012 09:12 PM
How do I track down a car I owned in 1979? riki 1979-1995 Mustang GT 3 03-11-2010 04:07 AM
so the snow owned my car Zim The Bar 29 12-07-2005 06:16 PM
car meet tonite...05 saleen got owned tedness The Bar 4 06-24-2005 10:27 AM
Dude in car gets flat out owned Brent The Bar 16 04-08-2005 03:02 PM
04:59 PM
