Twin turbo set - Mustang Evolution
Old 09-06-2014, 07:13 PM   #1
kyle_rivas's Avatar
Twin turbo set
I recently made a trade for a twin turbo set small turbos is their anything I should know beforehand? Is it missing anything and what size are they?
instagram @5.0_rivas
ID:	165352   Click image for larger version
ID:	165354   Click image for larger version
kyle_rivas is offline   Reply With Quote
Old 09-07-2014, 02:19 AM   #2
natestang07's Avatar
Which one is this going on the old mustang or the one you just picked up?
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 09-07-2014, 05:09 AM   #3
99_GRUMPY_GT's Avatar
Don't tell me this is another one of those universal kits?
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 09-07-2014, 09:59 AM   #4
kyle_rivas's Avatar
My teal 89 with the stripe and idk grumpy you would know more about this then me lol
Old 09-07-2014, 11:30 AM   #5
Did the seller or trader tell you what system that person bought it for? Or no one knows what the setup is for? If it is universal, you might as well sell it and by a kit. From what I have heard of recent by others is that it would cost more to piece a universal kit to work than just buying a model specific kit. I personally never have installed a turbo kit, I had a turbo 82 280zx once, but that is the extent of my turbo knowledge on cars.
Hell, now that you have two turbos, and now two stangs, split it and turbo both
Old 09-07-2014, 06:42 PM   #6
kyle_rivas's Avatar
Haha not a bad idea and the guy crashed his fox and had no use for it anymore
Old 09-08-2014, 09:58 AM   #7
Region: Oregon
Take everything you have for it to a performance shop and ask them how much it will cost for it to be installed and tuned. Ask them what else you need. From the pictures, it looks like you need intercooler pipes, injectors, spark plugs, a fuel pump, and fuel pressure regulator. I think I see blow off valves. And I see what could be a fuel pump, but I am not sure, so that's why I said you probably need one. For all I know, those little boxes could contain bigger injectors and colder spark plugs, but it's not apparent in the pictures. Even with two small turbos, you can push enough boost to warrant forged pistons. You might want to invest in a set of those with properly gapped rings for boost.
A lot goes into adding boost to an engine... or at least a lot goes into it if you want to do it right. The stock rods and pistons will hold up to mild boost (12psi and under) as long as it's intercooled. Anything more than that, and you are asking for trouble. Granted, anything more than 500ft/lbs at the flywheel and your block is just as probable to split as a rod or piston breaking.
If you are staying with stock internals and stock compression, I would stay at or under 10 pounds of boost, and shoot for 400hp.
DavidBoren is offline   Reply With Quote
Old 09-08-2014, 12:28 PM   #8
smurf stang's Avatar
Is that an On3 turbo kit?
Tough to tell if it is all there. Only one way to find out.
2016 VW GTI 2.0 Turbo
Old 09-10-2014, 08:11 PM   #9
rocknbronco's Avatar
What size is that turbo? If it was me I would twin one mustang and leave the other na. Its been said before take it to a performance shop and see what they say.
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
Old 09-10-2014, 09:47 PM   #10
kyle_rivas's Avatar
I told the guy never mind. ..
---------- Post added at 03:47 AM ---------- Previous post was at 03:46 AM ----------
What do yall think about the ebay turbos? Just wondering are they any good?
Old 09-11-2014, 05:09 AM   #11
Good idea and I would steer clear of the Ebay kits and find a kit that is offered by a reputable company.
Old 09-11-2014, 05:30 AM   #12
kyle_rivas's Avatar
I couldn't afford the turbo kit off of American muscle ima just go with the supercharger its a lot cheaper than the turbo
Old 09-11-2014, 05:40 AM   #13
Good call you can always slowly build a twin turbo engine over time.
Old 09-11-2014, 06:32 AM   #14
kyle_rivas's Avatar
Ya I will do that a little later on in life lol
Twin screw supercharger pro charger or single/twin turbo? bryn 2005-2010 Mustang GT 2 11-19-2016 10:11 AM
Twin screw v.s. Twin Turbo?? Mad_blackmusty 1996-2004 Mustang GT 11 11-19-2016 08:29 AM
twin turbo set up? 08mustanggt 2005-2010 Mustang GT 5 07-08-2013 11:32 AM
Can I get a twin turbo kit to work on a newer model a mustang than what the turbo kit was made for? warrane General Mustang Discussion 4 04-08-2010 11:09 AM
804 WHP Twin T57 03 Cobra vs 922 WHP Twin T60-01 SS JROC Pictures and Videos 27 08-31-2007 04:22 PM
07:41 AM
