Rear Control Arm Bushings & U-Joint ?'s - Mustang Evolution
Old 09-13-2014, 06:20 AM   #1
Hellish Horse's Avatar
Hey Guys,
I have a 94 Mustang GT that I'm considering changing the Rear Control Arm Bushings, U-Joints & Pinion Seal on.
I haven't ever done the Rears before so I'm wondering what I'm in for. Any advice or tips on doing this will be much appreciated.
I changed the Front Control Arm Bushings on my 04 & it was Pure H___ !!!
Had to Air Hammer out the old ones ( Took about an hour on each control arm).
Then had to rent a Ball Joint Press to install the New ones.
So am I going to have to do this on the Rear Control Arms ???
Just want to find out what I'm in for before I go buy the bushing kit. If it's too much of a PITA I'll just buy Control Arms.
I'd like to order the parts by Monday so I can do this next weekend so sure hope for advice before then.
THANKS GUYS...Much Appreciated !!!
Hellish Horse is offline   Reply With Quote
Old 09-13-2014, 07:16 AM   #2
Shifty 5.0's Avatar
U-joints if real rusted will give you hell and for rear control arms just do a tubular or 3 link setup to improve handling and traction. I plan on doing tubular setup soon and replacing rear springs with drag springs since you have to remove the old ones anyways that way il have lakewood 50/50 drag shocks and tubular and drag spring set up so the only thing left in the rear to do will be torque box supports, I've already done gears so the rear will be set besides the stock axles.
Shifty 5.0 is offline   Reply With Quote
Old 09-18-2014, 08:27 AM   #3
I'd just get a new set of lower control arms honestly. Screw putting new bushings in the stamped junk from the factory. If you are talking about uppers, I'm not sure if you can find the OEM rubber bushings anymore. I am a proponent of the stock uppers and aftermarket lowers but the older these cars get even I might have to upgrade to an aftermarket upper with spherical bushings to keep it from binding up. J&M makes a good setup for uppers that uses a poly/ball bushing but they are not adjustable. Adjustable is a big deal if you ever have a driveline angle issue.
Old 09-18-2014, 01:22 PM   #4
smurf stang's Avatar
To get old bushing out a torch is a great idea LOL.
Stock control arms are junk.
2016 VW GTI 2.0 Turbo
Old 09-18-2014, 01:55 PM   #5
Hey Scotty, When you say spherical bushings are you referring to the Oval Shaped Bushing in the lower position of the upper control arm ? If so they have them on Ebay.
I was thinking of New Lowers (Tubular) & Changing out the Bushings in the Uppers. I was reading on one of the Mustang websites that you need to install something that has to do with the Rear End Torque if you use Tubular Uppers. Can't remember what it was called.
Anyways, I'm thinking I'm going to have to do something real soon. Every time I Shift gears I get a Clunking sound right after I shift. Does it in reverse. Does it the loudest 1st to 2nd. Not as bad 2nd to 3rd but you still hear it. 3rd to 4th...only faintly & 5th...well...aint taking it on the Freeway like this so only been getting to forth.
There's no Oil on the Pinion Seal Area or the back of the Trans. I can't budge the drive shaft at either end. Not sure if it's the U-Joints or not but have no other idea what it could be.
Going to take a look at the Tranny Mount in a little bit. Not sure if that would cause the sound or not. Sure sounds like it's coming from the rear though.
Any Ideas ???
Old 09-19-2014, 07:51 AM   #6
When I say spherical I mean Heim joints. Or the J&M poly ball joint is kind of cool too but I don't think those are adjustable.
Old 09-19-2014, 01:01 PM   #7
Wow Totally Lost !!! Have no idea what those parts are or what they look like or anything.
Control arm and ball joint Notorious_rob Shelby Mustang 5 10-06-2014 03:44 PM
Front Lower Control Arm or Ball Joint Replacment? EthanGT03 1996-2004 Mustang GT 15 01-10-2014 06:37 AM
control arm/bushings blackGT91 1979-1995 Mustang GT 5 05-13-2012 07:47 PM
Rear control arm bushings conversion bigcolt45 1979-1995 Mustang GT 2 04-14-2012 10:18 PM
Moog rear lower control arm bushings bigcolt45 1979-1995 Mustang GT 9 04-12-2012 10:30 AM
06:52 AM
