Harmonic Balancer fell off - Mustang Evolution
Old 09-16-2014, 01:01 PM   #1
I took my fox body for a drive the other day but it was cut short when the harmonic balancer fell off. The moment I started the car I knew something was wrong. The car was shaking alot and was very noticable at stops. I also heard the noise of the power steering clearley. The noise was getting louder then I heard a few a clanks and saw something skid on the street in my side mirror. I picked the balancer up and managed to drive home. After the balancer fell the steering wheel became extremley stiff.
I do remember messing with the crank bolt and loosening it but i never that it would cause.
So my question is, is this a serious issue or do I just replace the balancer. Also, will the steering problem be fix once I install a new balancer.
Any help is appreciated
Sent from my SM-N9005 using Mustang Evolution mobile app
Alex5123 is offline   Reply With Quote
Old 09-16-2014, 03:32 PM   #2
Hellish Horse's Avatar
Not sure how you were able to drive home....but since you were able to you can probably just replace the balancer.
The pulley & all had to come off with it so you had no serpentine belt turning anything.
You must have been real close to home.
Hellish Horse is offline   Reply With Quote
Old 09-16-2014, 04:21 PM   #3
Yea I was a block away. Does this also explain the steering issue as well?
Old 09-16-2014, 04:54 PM   #4
Belt wasn't turning the power steering pump so I would think so.
Old 09-16-2014, 04:55 PM   #5
Thanks
Old 09-16-2014, 05:11 PM   #6
it fell off? Did you install it yourself? I just switched to under drive pulleys and the torque sequence has me sketched out. How did you torque yours?
TurboCobra is offline   Reply With Quote
Old 09-20-2014, 06:37 PM   #7
surfinglbi23's Avatar
What were you doing "messing with the crank bolt"?
surfinglbi23 is offline   Reply With Quote
Harmonic balancer or spout connector/distributor Finchms 1979-1995 Mustang GT 8 12-03-2012 04:01 PM
My new harmonic balancer does not have timing marks like my old one did! JayKranz 1979-1995 Mustang GT 159 07-17-2012 09:56 AM
changing harmonic balancer Zim 1979-1995 Mustang GT 6 11-07-2005 09:32 PM
12:59 AM
