Need timing help!!! - Mustang Evolution
Old 09-22-2014, 03:28 PM   #1
Shifty 5.0's Avatar
Need timing help!!!
So I adjusted my roller rockers and put everything back together and the only thing left was to put it in time. I do what I usually do when I put it in time. Put a finger in Number 1 spark plug hole till air pushes it out then bring your balancer to 0 degrees TDC put the distributor in and line up rotor with #1 spark plug wire then take out the spout connecter and Fire it up then put it in time.... But it won't fire up. It ran for a second once or twice but what am I doing wrong?
Shifty 5.0 is offline   Reply With Quote
Old 09-24-2014, 06:51 PM   #2
Davesorl04gt's Avatar
Check to see which motor you have. Ford has two 5.0's and each has a different firing order. The motors that came stock in early mustang's are High Output roller motors and then they have the Windsor.
Davesorl04gt is offline   Reply With Quote
Old 09-24-2014, 07:34 PM   #3
Shifty 5.0's Avatar
It's an 89 5.0. When I built the motor this is how I timed it but it's not working now
Old 09-26-2014, 05:41 AM   #4
Are you 180 out? Happens to the best of us.
Old 09-26-2014, 07:11 AM   #5
Shifty 5.0's Avatar
That's what I was wondering but how can you tell?
Old 09-26-2014, 08:24 AM   #6
Well, make sure you are at the top of the compression stroke, not the exhaust stroke. If you didn't have a valve cover off and weren't watching the rockers to make sure the intake rocker moves prior to the piston coming up you could have set #1 on the exhaust stroke. It pushes air out of the cylinder on the exhaust stroke too which is why you should visually look at the rockers.
Old 09-26-2014, 03:06 PM   #7
Shifty 5.0's Avatar
I always put my finger in the spark plug hole then When It starts to push it out I bring it to 0' TDC on the balancer
Need help timing my new cam digitalstang Pre-2005 V6 Mustang 0 03-24-2014 01:51 PM
Setting Timing without Timing Light ndeining Classic Mustangs 4 03-18-2014 10:12 AM
Timing problems need help kbolden50 1979-1995 Mustang GT 5 03-18-2013 07:55 AM
Need help with timing cover bolts WhiteCobra94 1979-1995 Mustang GT 33 08-11-2011 02:23 PM
need help figuring out timing bearbackcowboy Pre-2005 V6 Mustang 1 09-18-2008 09:31 AM
07:52 AM
