T5 tranny swap wireing questions? Help! - Mustang Evolution
Old 09-23-2014, 12:41 PM   #1
94gtconvert's Avatar
I can't seem to find good info on how to swap the t5 in and wire it up so the car will run. I have a 94 gt and just purchased a rebuilt t5 to replace my AODE. How do I wire it so the car starts and I have reverse lights without buying the t5 harness. Also I understand there is the clutch safety switch harness in my car but it's just jumped out, until I install the proper clutch brake assembly and plug the harness into the bracket. Thanks.
94gtconvert is offline   Reply With Quote
Old 09-24-2014, 09:31 AM   #2
Anyone?
Old 09-27-2014, 08:10 PM   #3
Alright I followed this link http://www.moddedmustangs.com/forums...on-w-pics.html , and copyed what he did. I also hooked the 2 harnesses up to the clutch assembly, and plugged in something that seems like it tells if the clutch is all the way engaged or not, and it wouldn't start. I plugged the jumper back into the only one that had on, the one on the brake pedal side, that tells if the clutch is completely engauged and it starts?!?! What gives.
Old 11-30-2014, 07:02 PM   #4
Well if it's a auto right ? And converting then you have a by pass in all autos make sure it's plugged in until get proper pedals then u can start car with out clutch . But there are 4 wires that were plugged in under car from auto 2 are for reverse and 2 for clutch safety swith if not using u cross them to by pass car will start just did same swap on 88 5.0 had same issue
goosetoff is offline   Reply With Quote
Old 11-30-2014, 07:04 PM   #5
Thanks but I needed info like that 3 months ago. I figured it out thanks .
Old 11-30-2014, 09:10 PM   #6
No prob glad could help had same problem drove me nuts
Door sub wireing Questions Alerotaz Mustang Audio & Video 1 04-27-2014 09:55 AM
Door sub wireing Questions Alerotaz Mustang Audio & Video 0 04-23-2014 10:01 AM
radio randomly stopped working it seems to be wireing any help The420fox 1979-1995 Mustang GT 8 06-04-2013 12:27 PM
I have a 1984 mustang lx v6 with wireing prob will putting a new hornes fix it help please? Eairrdsidh 1979-1995 Mustang GT 3 12-12-2011 02:37 PM
wireing short? 96mustangv8 2005-2010 V6 Mustang 2 05-11-2011 05:39 PM
06:37 AM
