Another 5.0 build - Mustang Evolution
Old 09-28-2014, 07:22 PM   #1
Another 5.0 build
Name:	ImageUploadedByMustang Evolution1411953466.552606.jpg
ID:	167008Click image for larger version
Name:	ImageUploadedByMustang Evolution1411953485.831098.jpg
ID:	167009Click image for larger version
Name:	ImageUploadedByMustang Evolution1411953499.446684.jpg
ID:	167010Click image for larger version
Name:	ImageUploadedByMustang Evolution1411953514.240199.jpg
ID:	167011Click image for larger version
Name:	ImageUploadedByMustang Evolution1411953531.618500.jpg
ID:	167012Click image for larger version
Name:	ImageUploadedByMustang Evolution1411953540.493197.jpg
ID:	167013Click image for larger version
Name:	ImageUploadedByMustang Evolution1411953552.114877.jpg
ID:	167014Click image for larger version
Name:	ImageUploadedByMustang Evolution1411953564.470983.jpg
ID:	167015Click image for larger version
Name:	ImageUploadedByMustang Evolution1411953578.855088.jpg
ID:	167017Click image for larger version
Name:	ImageUploadedByMustang Evolution1411953594.763335.jpg
ID:	167019Click image for larger version
Name:	ImageUploadedByMustang Evolution1411953604.553304.jpg
ID:	167021Click image for larger version
Name:	ImageUploadedByMustang Evolution1411953615.245787.jpg
ID:	167022 Click image for larger version
Name:	ImageUploadedByMustang Evolution1411953631.520010.jpg
Something going on with cylinder 2 and 6
Name:	ImageUploadedByMustang Evolution1411953692.606638.jpg
ID:	167024Click image for larger version
Name:	ImageUploadedByMustang Evolution1411953713.685598.jpg
ID:	167025Click image for larger version
Name:	ImageUploadedByMustang Evolution1411953728.137063.jpg
ID:	167026Click image for larger version
Name:	ImageUploadedByMustang Evolution1411953739.695158.jpg
ID:	167027Click image for larger version
Name:	ImageUploadedByMustang Evolution1411953749.535879.jpg
Tasteslikeink is offline   Reply With Quote
Old 09-29-2014, 07:53 AM   #2
Region: Oregon
I like the plethora of pictures, but what are they? Like what cam, heads, rockers, etc.
What are your plans and goals for this build? Keep us posted.
DavidBoren is offline   Reply With Quote
Old 09-29-2014, 09:13 AM   #3
Haha I have more pics to post THEN I was going to list everything. But thank you for noticing. It's a top end rebuild right now.
Old 10-01-2014, 02:47 AM   #4
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG [/IMG]
Old 10-01-2014, 03:31 AM   #5
Edelbrock valve covers pt#4260, edelbrock e-205 heads Edelbrock 5027
Cylinder Head; E-Street; Assembled; Natural Aluminum; 205 CC Intake Port; 62 CC Exhaust Port; 60 CC Chamber Volume; 2.08 Inch Intake Valve; 1.60 Inch Exhaust Valve; 1.55 Inch Spring Diameter; Single; With Pushrod Guides; Rocker Studs, Ford Racing hardened stock length pushrods, Competition Cams 35-304-8 Camshaft; Blower; Hydraulic Roller; 1800-5300 RPM Range; 215 Degree Intake Duration @ 0.050 Inch Lift; 224 Degree Exhaust Duration @ 0.050 Inch Lift; 0.533 Inch Intake Valve Lift; 0.533 Inch Exhaust Valve Lift; 114 Degree Lobe Separation, edelbrock double roller timing chain and gears, Comp Cams 1.6 ratio roller rockers, summit distributor with comp cams brass gear, Ford Racing roller lifters, Vortech S1 supercharger, 10pd pulleys with 100mm maf housing and slotted maf/iac from 06 mustang GT, Anderson power pipe, deauchwerks 42* injectors, ford racing 9mm spark plug wires, Mallery hyfire VI digital multi strike cd ignition, AEM UEGO wide and, AEM boost gauge, Tial recirculating bov, Ford Racing Timing cover, BBK fuel regulator, BBK shorty headers, BBK off road long careless X-pipe 2 1-2" header back, svt side skirt exhaust, custom gasket ported GT40 upper and lower intake, trick flow elbow, performance 75mm throttle body, catch can, center force clutch, all powered by Moates QH and dirtydirtyracing tunes, BBK 255lph fuel pump, braided oil return and feed lines,
Braided fuel lines.
Old 10-01-2014, 03:40 AM   #6
I've spent $4k on the suspension too. But those pics and info come when that part of the install starts.
Old 10-01-2014, 09:13 AM   #7
smurf stang's Avatar
Very cute...should be fun.
2016 VW GTI 2.0 Turbo
Old 10-01-2014, 10:06 AM   #8
Cant go wrong with vortech
Skarakis007 is offline   Reply With Quote
Old 10-17-2014, 06:01 AM   #9
Another day, another problem SixBanger General Mustang Discussion 69 03-05-2014 11:40 AM
Another Year, Another USC FAIL!!!!!!!!!!!!!!!!!!! Brent The Bar 20 09-27-2008 07:08 PM
Well, I got another car, guess I won't be getting another stang anytime soon :(. Rick0636 The Bar 12 09-25-2005 10:10 PM
Supercoupe Build Up Black95GT Pre-2005 V6 Mustang 11 01-03-2004 10:01 AM
build me a system Rellik Mustang Audio & Video 11 10-20-2003 11:42 AM
09:22 PM
