Relay. - Mustang Evolution
Old 10-01-2014, 09:02 PM   #1
Davesorl04gt's Avatar
Relay.
In the process of cleaning and painting the engine bay on my 87 GT I found a relay mounted on the passenger side about over the tire with the insulation on the wires melted off. No other signs of anything wrong so I imagine something shorted in the relay and got the wires hot. Problem is I cant find any info on what the relay is for and the part numbers on the relay are faded. Any on have an idea what the relay is for so I can find a new one.
Davesorl04gt is offline   Reply With Quote
Old 10-02-2014, 05:58 AM   #2
ALMOST STOCK's Avatar
Got a picture of that relay?
ALMOST STOCK is offline   Reply With Quote
Old 10-02-2014, 09:45 AM   #3
Not good at this picture thing, but here goes.
http://www.mustangevolution.com/foru...1&d=1412264174, http://www.mustangevolution.com/foru...1&d=1412264586
Old 10-02-2014, 09:54 AM   #4
Here is more.
ID:	167228   Click image for larger version
ID:	167230   Click image for larger version
Old 10-02-2014, 04:55 PM   #5
That your A/C cutoff relay.
Old 10-02-2014, 07:23 PM   #6
Are you sure, because the groove on the right side of the relay isn't on any A/C relays I can find online. Doesn't that mean my harness wont plug in to them?
Old 10-03-2014, 05:55 AM   #7
This is the reason I said it's your WOT A/C cutoff relay.
Old 10-03-2014, 08:19 AM   #8
Your absolutely right. Maybe there is different connections for different year's or car's. Where do you find these diagrams? Would be helpful in putting things back together and for identification of part's.
Old 10-03-2014, 04:39 PM   #9
The diagram I posted is from the 88 Mustang EVTM which looks identical to my 89 EVTM.
I saved a link to a zip folder a few years ago for the 87 EVTM and I'm not sure how to post the link because it goes directly to the zip folder and asks if I want to open it or save it. The folder is 67 MB so I can't post the it here.
This is for the 88 EVTM
1988 EVTM
Old 10-03-2014, 06:50 PM   #10
1988 EVTM
Thank you very much. That will save me a lot of time from trial and error.
Old 10-03-2014, 08:29 PM   #11
smurf stang's Avatar
I do not think there is a diagram or picture Almost Stock doesn't have. He is dreamy.
2016 VW GTI 2.0 Turbo
Old 10-04-2014, 05:10 PM   #12
oooooooooooooooooooooK, I'll have to take your word on that.
Old 10-05-2014, 08:40 AM   #13
You can't believe everything smurf stang says.
Old 10-05-2014, 08:53 AM   #14
Does it look like one of these?
More Information for FOUR SEASONS 35987
More Information for AIRTEX / WELLS 1R1271
More Information for BWD/NIEHOFF R712
If it does then you can find it at Rockauto under 1987 FORD MUSTANG 5.0L 302cid V8 : Electrical-Switch & Relay : A/C Compressor Relay.
RockAuto Parts Catalog
Old 10-05-2014, 11:51 AM   #15
No, that's all I've been finding. Every thing is the same except the groove on the oppisite side from the clip that holds the harness on. Tried to take some better
pictures.
ID:	167429   Click image for larger version
Old 10-05-2014, 11:56 AM   #16
Unless the relay has that groove my harness won't plug it to it. Found one, but it say's it's a starter relay. Has numbers that match one part on the ole relay, 11433. I have read that some of these relays are interchangeable. Like Fuel pump and convertible top relays, and A/C cutoff relays. 20 amp.
Window fuse/relay jjpea 1996-2004 Mustang GT 1 03-13-2009 10:15 PM
01 GT Horn Relay lowering kit 1996-2004 Mustang GT 8 01-10-2008 07:41 AM
07:36 PM
