Rear axle moves left and right. - Mustang Evolution
Old 10-09-2014, 07:50 AM   #1
prototype ss's Avatar
Recently I let my friend drive my car. And while I was behind him driving his car. I noticed that when he would accelerate the axle would pop out to the right. And swing back to the left when he would let go of the gas.. Does anyone know what it could be.. Any help is appreciated thanks!
prototype ss is offline   Reply With Quote
Old 10-09-2014, 02:33 PM   #2
Hellish Horse's Avatar
My 1st thought is Worn out / Cracked / Dry Rotted Control Arm Bushings.
Hellish Horse is offline   Reply With Quote
Old 10-09-2014, 02:42 PM   #3
Replace all the bushings and install a Panhard bar.
Old 10-09-2014, 04:21 PM   #4
Oh ok. Do you know how much that costs on average.? Thanks for the info guys.
Old 10-09-2014, 04:41 PM   #5
You can get a complete set of Bushings for about $100 on Ebay. Not sure about a Pan Hard Bar.
Old 10-09-2014, 05:06 PM   #6
Nice...Thanks dude!!
Old 10-09-2014, 07:04 PM   #7
I just remembered my car is 5 lug. Does that matter?
Old 10-09-2014, 07:10 PM   #8
The Panhard bar is amazing. It keeps the axle centered at all times. Came stock on 05+ nothing before that. I highly recommend it. One of the best things I've done to my 01.
Old 10-09-2014, 07:13 PM   #9
Did you have to do any modifying to install the panhard bar?
Old 10-09-2014, 07:47 PM   #10
Well you want subframe connectors first, other than that no. You just need a helper and a heavy dude drill bit lol, have to drill a few holes into the frame for it. Not too bad.
Old 10-09-2014, 08:16 PM   #11
Lol. Where did you get the subframe connectors?
Old 10-10-2014, 02:26 AM   #12
You can get sub frame connectors on Ebay for about $100 also. They also sell them in a set with upper & Lower Control Arms for around $170. They're not Top of the Line...but they work fine as I've used them in the past on my 04 Mustang.
4 or 5 Lug shouldn't make a difference as you're not dealing with Brakes, Rotors or anything like that. Just check your Bushings on your Upper Rear Control arms to see if they are Oval Shaped or Round so you order the right ones. They make them both ways.
Old 10-10-2014, 10:48 AM   #13
smurf stang's Avatar
I would put the car up on a lift to check it out first.
Could be a lot going on under there.
2016 VW GTI 2.0 Turbo
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 05:12 PM
Rich on right and left bank Brake.handle 1996-2004 Mustang GT 5 08-19-2012 04:48 PM
Need help. Getting speeding tickets left and right chris098 The Bar 18 10-10-2008 05:08 PM
WTB: Left and Right 2005+ 4.0L headers JasonVMP Mustang Parts for Sale and Wanted 0 01-30-2006 05:45 PM
So who does the left and the right despise the most? Brent The Bar 3 09-12-2005 01:01 PM
10:54 PM
