Timing question?.. - Mustang Evolution
Old 10-09-2014, 08:03 PM   #1
antnvlz1294's Avatar
Exclamation Timing question?..
Have a stock 1988 mustang gt 5.0 5 speed. The vehicle is completely stock with the exception of a sound system and a full exhaust(headers, pipe and mufflers). At idle it is anywhere between 1100-1200 rpms but if driven around for about 45 miles or so it will stoke times idle at 1400rpm all the way up to 2000 rpms after a complete stop at a light. Is my timing too high? I didn't see any part of the cable stuck on anything or anything like that but my last foxbody which was a 5.0 but an lx idled at about 900 rpms. Is my timing too high? What should it be set at because it seems like it's just going through gas. Thanks again.
antnvlz1294 is offline   Reply With Quote
Old 10-09-2014, 08:48 PM   #2
Sounds like timing or ur tps switch.
2fastfoxbody is offline   Reply With Quote
Old 10-10-2014, 05:19 AM   #3
Throttle position sensor?
Old 10-10-2014, 09:18 AM   #4
Yes sir.
Old 10-11-2014, 06:52 AM   #5
Yes sir.
I'll use an ohm meter to figure out the voltage and adjust it. Let you know how that goes.
Old 10-13-2014, 09:01 AM   #6
smurf stang's Avatar
Run your codes.....why, cause it's free and might give you an idea of what's wrong.
Secondly clean the IAC.
Clean the MAF.
Check your grounds.
Check for vacuum leaks.
2016 VW GTI 2.0 Turbo
Old 10-13-2014, 12:10 PM   #7
Clean the MAF.
Check your grounds.
What should I clean the iacv with?
Don't have maf 88 came with speed density unless it was a California edition other wise it wasn't until 89 that maf came into play.
Grounds are good
Will check for vacuum leaks and I don't have a coder, how do I pull codes without obd1? An no I do not have a check engine light either.
Old 10-13-2014, 12:20 PM   #8
Grounds are good
Google it.
You can use a jumper wire on the test connector and the codes will flash on the Check Engine Light. No code reader needed.
Old 10-13-2014, 12:25 PM   #9
Originally Posted by straybullitt View Post
Google it.
Okay I don't have a jumper wire so how about a paper clip? Lol. Diagram for jumping?
Old 10-13-2014, 12:31 PM   #10
Lol.
Yes. A paper clip can be used. Just don't let it touch any metal while you are doing the test.
As for the diagram... GOOGLE IT!!!
Old 10-13-2014, 12:33 PM   #11
Lol.
But why Google it when I have good people like you who could tell me lol. Just kidding I'll google it! Thanks. Let you all know what I get.
Old 10-13-2014, 12:42 PM   #12
Haha.
There's also some YT vids that show the procedure. If you have some codes, the hardest part is to decipher what the light flashes are telling you. Take your time and pay close attention to the time intervals between the flashes. Watch it go through the cycle a few times if you have to. It's pretty straight forward.
Good luck!
Old 10-13-2014, 02:38 PM   #13
Well you never said it was a SD car plus it could have been swapped also but.....whatever.
DIY KOEO/KOER http://sbftech.com/index.php/topic,2471.0.html
CODES
http://sbftech.com/index.php?PHPSESSID=7261a4935687afe79b81c982b1b049ec&/topic,849.0.html
Base Idle Reset http://sbftech.com/index.php/topic,1031
Setting Timing without Timing Light ndeining Classic Mustangs 4 03-18-2014 10:12 AM
94 Mustang timing question workmail21 1979-1995 Mustang GT 5 09-20-2012 02:23 PM
Timing question GT89 1979-1995 Mustang GT 4 07-25-2012 11:20 AM
Timing question??? FordFan87 1979-1995 Mustang GT 47 01-14-2011 02:18 PM
Timing question damighty5.0 1979-1995 Mustang GT 12 05-22-2006 04:23 PM
05:16 AM
