Fuel injector o rings - Mustang Evolution
Old 10-11-2014, 06:58 AM   #1
antnvlz1294's Avatar
Hey everyone. 88 mustang gt with some of the fuel injectors leaking fuel from the side that goes in the plenum, not the fuel rail. I bought 8 felpro fuel injector rings to redo the bottoms and I would use silicone grease to lube them up. How do I get the upper intake manifold off though? I don't have a throttle body gasket because it would take a week to get to me but I do have a felpro intake gasket set which includes the upper and lower. Do I just take off the air box, then I assume there's 6 screws to the throttle body and I can pull it off as one big assembly, disconnecting the egr lines also? Also where is the little valve to relieve the fuel pressure in the lines?
antnvlz1294 is offline   Reply With Quote
Old 10-12-2014, 02:12 AM   #2
Hellish Horse's Avatar
Is it really necessary to remove the throttle body ? Why not disconnect the air box & remove the 6 upper intake bolts & just move it off to the side a little to take the injectors out. There's also 2 screws on each side of the Fuel Rails holding it down. Just disconnect the rails & wiggle the injectors out.
Hellish Horse is offline   Reply With Quote
Old 10-12-2014, 07:59 AM   #3
That's exactly what I ended up doing
Old 10-12-2014, 09:13 AM   #4
kool !!!
Old 10-12-2014, 09:19 AM   #5
kool !!!
Thanks for the help brother!
Fuel injector sizes LeviG2010 2011-2014 Mustang GT 0 05-23-2012 03:54 PM
1995 3.8 Mustang Knocking Sound <Transmission> Fuel Injector<AOD????? HELP> Jsan105 Pre-2005 V6 Mustang 2 10-26-2011 07:24 PM
Mustang GT Fuel Injector 504 Stang Rida 1996-2004 Mustang GT 4 09-01-2011 09:12 PM
Fuel Injector Rating RetroTA 2005-2010 Mustang GT 2 08-16-2006 01:36 PM
Fuel injector how to's? DarkShadow Pre-2005 V6 Mustang 4 03-08-2006 08:41 PM
07:56 PM
