Speed density ECM in a mass air car? - Mustang Evolution
Old 10-11-2014, 12:33 PM   #1
ponie1992's Avatar
Question Speed density ECM in a mass air car?
Working on a friend's 91 GT. Had to fix a mess with the vacuum lines. They were routed all wrong. Then I noticed a vacuum line was run from the intake to the MAP/BAP sensor. On a mass air car, there is no need for a vacuum line there as it reads atmospheric pressure. I disconnected it and plugged the intake. The reason for going through the vacuum system is the car is running extremely rich. I fired it up and it ran like complete poop. Checked vacuum lines again and didn't see an issue. Then, I questioned why it ran so much better with that vacuum line hooked up to the BAP sensor. So it hit me, I think someone installed a speed density ECM in this car and they tried to just give the BAP sensor some vacuum. Could this be why it's running so rich? Is the wiring harness different other than having the connections for the MAF? Any help would be great. I have a friend with a mass air ECM, so I'm gonna try it when I can.
ponie1992 is offline   Reply With Quote
Old 10-12-2014, 09:10 AM   #2
ponie1992's Avatar
Anyone?
Jeremy
2016 Ruby Red PP GT
Old 10-13-2014, 09:26 AM   #3
smurf stang's Avatar
Different wiring harnesses. So a SD ecu on a MAF car is not good.
2016 VW GTI 2.0 Turbo
Old 10-13-2014, 10:04 AM   #4
ponie1992's Avatar
I was doing a little research today and found that the pinout is different. Looks like that may explain some of the codes I'm getting. Seems like all they did was install a SD ECM and run a vacuum line to the MAP sensor. Smh!
Jeremy
2016 Ruby Red PP GT
Bigger injectors and CAI on speed density car. sawyers_15 1979-1995 Mustang GT 0 01-29-2014 04:29 PM
Speed density Mustangnutz 1979-1995 Mustang GT 10 07-01-2013 03:28 PM
speed density vs mass air flow Giles85 1979-1995 Mustang GT 4 02-03-2012 06:30 AM
86 mustang gt speed density mods Dgasca101 1979-1995 Mustang GT 6 04-07-2011 12:23 PM
Speed density to MAF Bigdawg15533 1979-1995 Mustang GT 0 01-02-2011 10:10 AM
02:40 AM
