Heat - Mustang Evolution
Old 10-12-2014, 09:14 PM   #1
antnvlz1294's Avatar
Exclamation Heat
Hey everyone. 1988 mustang gt 5.0. I bought this car last week with a few little issues that I'm knocking out as I go along but the one big issue that I need to take care of is that I have no heat. A little background is that the guy said the A/C condensir doesn't work and needs to be replaced and that the heat is "intermintant". I've had the car since Wednesday and I haven't gotten the "intermintant" heat to work lol. I set the temperature to the hottest and adjust the knob to the defroster selection or even the vent selection but when I do nothing happens, even if I cycle through the low-high settings. I feel no heat, nothing comes out of the vents and I feel nothing kick on. Is this the blower motor that's bad? Need heat because this is my daily driver until I can get a cheap pos daily driver. Thanks guys
antnvlz1294 is offline   Reply With Quote
Old 10-14-2014, 01:15 AM   #2
Chris01's Avatar
When u cycle thru the blower setting does the blower come on? If it does that good but then it means u need a new heater core which is under the dash
Chris01 is offline   Reply With Quote
Old 10-14-2014, 05:11 AM   #3
When I cycle through the blower settings nothing comes on at all. I already know not to put it to a/c because the condensir is bad but still no heat.
Old 10-14-2014, 10:59 AM   #4
Chris01's Avatar
Did you check your fuses? If so it could be the switch or the blower
Old 10-14-2014, 11:01 AM   #5
My fuses are all good. I'm thinking it could be the ignition switch possibly since the blinkers don't work either?
Old 10-14-2014, 03:35 PM   #6
Chris01's Avatar
Ok so u have other problems with the car. What else Doesn't work
Old 10-14-2014, 03:40 PM   #7
Reverse lights, passenger side window doesn't like to go back up unless I wait a bit and dimmer switch is bad. That's all.
Old 10-14-2014, 03:44 PM   #8
Chris01's Avatar
I'm guessing u bought the car with all these problems
Old 10-14-2014, 03:50 PM   #9
Yeah. I've owned a fox before so to me those are little things since I've dealt with them before. The only things that are new to me is this heater issue because I had heat before and this power window issue because I had no electric anything lol
Old 10-14-2014, 03:56 PM   #10
Chris01's Avatar
Heat
Have u check bulbs and/or flasher relay? Could be simple as mine was but behind the hazard switch the wires come loose something and need to be shoved back into the plug because the blinker are wired thru the hazard switch. As for heat take the wires of the plug and hot wire it just to see if the blower motor work
Old 10-16-2014, 09:05 PM   #11
Hot wire the wires? How so?
94-98 Heat Extractor Hood Roadhawg Mustang Audio & Video 28 08-02-2006 03:53 PM
WTB: Cobra Heat Exchanger SwpdMR2 Mustang Parts for Sale and Wanted 2 05-02-2006 12:33 PM
run 16.3 in high heat/humid...low temp good for 15's? tedness Pre-2005 V6 Mustang 7 01-02-2006 12:56 PM
Some new(er) pics of my car..bringing the heat mike!! greenflash00 Mustang Audio & Video 18 06-24-2004 02:26 PM
03:08 AM
