drive shaft question. - Mustang Evolution
Old 10-15-2014, 05:01 AM   #1
vettekiller's Avatar
I replaced my rear output shaft seal in my 89 5.0 , well I put the driveshaft back on and never thought it might matter which holes it went in. I know I should have marked it , but it just slipped my mind. I did notice the bolts were a lot harder to screw in then they were to take out ,, any words of wisdom would be appreciated. Thanks
vettekiller is offline   Reply With Quote
Old 10-15-2014, 05:08 AM   #2
BTW it is a aluminum drive shaft
Old 10-15-2014, 12:27 PM   #3
smurf stang's Avatar
Well bolt it up and if it vibrates some swap holes till it doesn't vibrate.
Or it just might be good the first time around.
2016 VW GTI 2.0 Turbo
Old 10-17-2014, 02:20 AM   #4
Its harder to screw in because you probably were using the 4 holes that were not used originally. There are 8 holes total so the 4 unused ones were crudded up from decades of not being used. As long as you got it tight they should be fine though.
Old 10-17-2014, 02:27 AM   #5
Ok cool, thanks guys for the peace of mind
Question about a new drive shaft. Thenervemann 1996-2004 Mustang GT 16 10-16-2013 11:34 AM
Mustang drive shaft question (10 points)? h¡varr Pre-2005 V6 Mustang 4 03-07-2010 08:46 AM
Aluminum Drive Shaft? Paincake1 Pre-2005 V6 Mustang 5 01-22-2009 05:41 PM
FS: NEW IN BOX Drive shaft loop Loco Mustang Parts for Sale and Wanted 0 11-27-2005 09:05 AM
Got my aluminum Drive shaft and Bullitt pedals WooHoo!!! Danger Dude Pre-2005 V6 Mustang 13 12-09-2003 07:57 AM
07:37 PM
