Engine overboard kits - Mustang Evolution
Old 10-20-2014, 07:41 AM   #1
Hello all. I was wondering if someone could point me in the right direction to buy a HO 5.0 302 engine rebuild (overhaul) kit. Looking for a complete kit and wanting the best bang for my buck. Only thing I'm upgrading is the cam. Will have heads worked over at local head shop. Any help wld be appreciated
---------- Post added at 01:41 PM ---------- Previous post was at 01:40 PM ----------
Sorry about that....overhaul kit not overboard kit
jsdoogie91gt is offline   Reply With Quote
Old 10-20-2014, 12:25 PM   #2
Chris01's Avatar
What are u looking for just a complete gasket kit
Chris01 is offline   Reply With Quote
Old 10-20-2014, 02:23 PM   #3
No. I want complete overhaul kit. All gaskets and pistons, rings, everything to completely rebuild one.
Old 10-20-2014, 05:15 PM   #4
Chris01's Avatar
I dont know of anything that includes items like that but it's not hard to get them. Why are you rebuilding it. Have u built one before
Old 10-20-2014, 07:42 PM   #5
No I havent. I have engine experience. It's got 140,000 miles but wld live to freshen it up with a complete overhaul. Found something similar to what I'm looking for at Summit Racing and Jegs. Pistons, rings, oil pump, all gaskets etc for roughly $400
Old 10-20-2014, 07:59 PM   #6
Chris01's Avatar
Ok well u want the same style piston so u don't change the compression ratio. Are you getting the Block refinished by a shop? There's a lot more than just taking it apart and putting new stuff on.
Old 10-20-2014, 08:49 PM   #7
I know the block needs honed too. What else needs to be done?
Old 10-20-2014, 09:34 PM   #8
smurf stang's Avatar
Well it might need more than a hone so buying pistons prior to the shop checking out might not be a good idea unless you already plan on an overbore of .030.
Also there is the choice of pistons from simple and cheap to forged and expensive.
2016 VW GTI 2.0 Turbo
Old 10-20-2014, 10:31 PM   #9
Chris01's Avatar
Yea .030 is good that's what I have. The first things that come to mine are since the motor is apart is main bearings, oil pump, new rod studs, timing chain, water pump, gasket set, rear seal, possible new cam, piston and rings and I'm sure there are some more small parts that are good to replace.
Old 10-21-2014, 05:07 AM   #10
Ok sounds good
Old 10-21-2014, 07:47 AM   #11
You see there is not one comprehensive kit that has all of that.
You will have to piece together some of these parts.
Add a hardened oil pump shaft, arp rod bolts and whatever is needed which is hard to say without going in there first.
Old 10-21-2014, 12:06 PM   #12
Chris01's Avatar
The motor I have now I wanted to freshin it up until I took #1 cylinder and that changed all my plans Click image for larger version
Name:	ImageUploadedByMustang Evolution1413914797.099729.jpg
Old 10-21-2014, 01:08 PM   #13
Like I said....you never know till you pop the top.
She might run good, not smoke, burn oil but that cylinder could be deformed in all types of ways. All it takes is one cylinder.
Old 10-21-2014, 01:12 PM   #14
Chris01's Avatar
Yep can't judge a book by its cover
Old 10-22-2014, 05:11 AM   #15
True enough. Thanks everyone
Engine Dress Up Kits avengnd 2011-2014 Mustang GT 15 01-22-2012 07:20 AM
2011 v6 engine dress up kits fordfan100 2011-2014 V6 Mustang 4 02-13-2011 10:05 PM
Trick Flow engine upgrade kits Albaraptor 1979-1995 Mustang GT 14 02-03-2011 06:42 PM
Body Kits, Body Kits, Body Kits! *DUW* *WW* Dom Mustang Audio & Video 75 02-01-2004 07:11 PM
British Columbia Body Kits cyphorx Mustang Audio & Video 1 07-19-2003 09:24 PM
04:49 AM
