306 swap - Mustang Evolution
Old 10-23-2014, 07:24 AM   #1
306 swap
So I have an 88 notchback I bought already swapped with a 302 from a similar year. Then I planned on building this motor but instead just bought the full engine from summit with the e303 cam, gt40 heads, forged Pistons.
Then I grabbed all the supporting things 70mm throttle body , maf sensor , 24 lb injectors, gt40 upper and lower intake. Every bushing I could think of replaced with polyurethane bushings, eibach struts shocks, sway bars.
I bead blasted the upper and lower intake while taping off the holes but I've read it's Impossible to get all the aluminum oxide out and the engine will vacuum it into the cylinders (bad).
Is the true? Also I read something about changing the gear on my stock distributor for the e303 cam. Also I've failed to find what temp gauge I should run, 220, 240 etc
Any info or suggestions would be great since I'm pretty novice
joedan890 is offline   Reply With Quote
Old 10-24-2014, 12:38 PM   #2
smurf stang's Avatar
Well if you bead blast it, then wash it to be sure.
Temp gauge 240 is good.......mech or electric?
2016 VW GTI 2.0 Turbo
Old 10-24-2014, 01:48 PM   #3
306 swap
Electric, it's just the stock one
306 project Stang89 1979-1995 Mustang GT 7 10-17-2011 11:37 AM
90 Mustang Built 306` 98RedGT 1979-1995 Mustang GT 1 07-23-2011 10:43 PM
engine swap from v6 to 306 ballen666stang Pre-2005 V6 Mustang 1 01-13-2011 10:36 PM
91 Mustang GT 306 Running Pretty Hot! 91StangGT5.0 1979-1995 Mustang GT 8 10-22-2009 08:01 PM
Help with a 306 build Jay Rod 5.0 1979-1995 Mustang GT 7 04-20-2007 05:32 AM
12:54 AM
