Broken pistons? And replacement?? - Mustang Evolution
Old 11-01-2014, 09:35 AM   #1
Foxbody91's Avatar
Lately there's been a rattling noise under my hood, the engine sounds louder than normal and it'll idle high sometimes. I've had to turn the idle down twice now. At first I thought it was an oil problem because when I put oil in it, the noise stopped for a couple weeks, now it's back again. Asked a friend who rly doesn't know much about cars but since the sound is coming from what seems like inside the engine, pistons maybe wasn't a bad analysis. So could this be a bad piston and if it is how do I fix it??
Foxbody91 is offline   Reply With Quote
Old 11-01-2014, 12:17 PM   #2
Liebert91stang's Avatar
The car would barley run or run like hell if it were a piston.sounds like a valve is chattering or maybe a pushrods.has it started smoking since the noise?
Liebert91stang is offline   Reply With Quote
Old 11-01-2014, 01:13 PM   #3
Foxbody91's Avatar
No not smoking abnormally, the normal smoke in the morning when it's cold that's it. It does need new valve springs tho u think that could be it?
Old 11-01-2014, 02:39 PM   #4
Yes I would say your hearing a valve chattering.i would replace the springs
Old 11-01-2014, 02:43 PM   #5
Foxbody91's Avatar
Any tips on how to do that?
Old 11-02-2014, 04:29 PM   #6
If you haven't had your hands inside a motor I wouldn't start on valve springs.check around to find a good mechanic.
Old 11-02-2014, 04:49 PM   #7
Foxbody91's Avatar
Nope never on the inside of the motor itself I've been learning as I go
Old 11-02-2014, 04:51 PM   #8
The best way to learn is hands on but I would have someone who knows how to replace them with you while your doing it.would hate to see you go through all the work to have to take it back apart.
Old 11-02-2014, 04:55 PM   #9
Foxbody91's Avatar
Heard. I've got a couple guys I can have help out. Ill also have to order more springs any recommendations? Sry about all the questions too.
Old 11-02-2014, 05:48 PM   #10
Ford racing makes good springs and also comp cams.around $40 for a set
Old 11-02-2014, 05:58 PM   #11
I would also change valve seals while you have it apart.will need head gaskets as well.
Old 11-02-2014, 07:22 PM   #12
Foxbody91's Avatar
Ok thanks. Will post results in couple weeks
Old 11-02-2014, 07:44 PM   #13
smurf stang's Avatar
How do you know you need new springs?
What mods do you have?
2016 VW GTI 2.0 Turbo
Old 11-03-2014, 12:49 PM   #14
Foxbody91's Avatar
When I bought the car guy said it needed new springs. Mods: it's a 91' roll block 30 over,10.5 flat top pistons,e303 Motorsport cams, roller lifters, rocker arms,edel alumi intake,750 Holley carb 4 barrel( currently using 2), gt40p heads, and 3.73 gears. Little misc stuff I got the high torque mini starter, msd ignition box. Guy told me when I got the car it needed new valve springs and a couple of trim pieces for my trunk
Old 11-04-2014, 06:46 AM   #15
Hellish Horse's Avatar
Could be a Broken Spring, Broken Roller Rocker, Roller Rocker not lined up right on the end of the Valve Stem, maybe a bent Push Rod.
If you change Valve Springs you'll need to buy a Valve Spring Compressor which is $8 @ Harbor Freight. I believe you have to blow air through the Spark Plug Hole to keep the Valve from falling while you're changing each spring.
There's some good Video's on U-Tube that will show you how to do it.
Hellish Horse is offline   Reply With Quote
Old 11-04-2014, 07:48 AM   #16
Well if those are the stock springs in those heads then hell yeah you need new springs. They will float way before 5k.
750 carb is way too big.
Here is a good little website to read.....
Five.Oh Info : The Ultimate Ford GT40 and GT40P Cylinder Head FAQ
Old 11-04-2014, 11:35 AM   #17
Foxbody91's Avatar
Yea I kno the 750 is too big I've had zero luck on finding 650
Old 11-04-2014, 12:17 PM   #18
A good working 600 to 650 is good enough for mild builds. Got get the tune spot on tho.
Edelbrock, Holley, Avenger, Demon......
Pistons and Camshaft MSTNGLX1 2.3 Mustang 5 05-24-2013 08:27 AM
pistons rods and crank upton7 Mustang Parts for Sale and Wanted 0 02-18-2010 06:27 PM
347 Wiseco Pistons And H-beam Rods BIGG-GREGG Mustang Parts for Sale and Wanted 0 11-19-2006 06:22 PM
Turbo rotary GTR mustang with pistons and headers lowflyn The Bar 9 01-14-2006 08:06 PM
New Pistons and Rods GT-Eater Pictures and Videos 18 07-29-2005 02:50 PM
09:45 PM
