1995 5.0 need help - Mustang Evolution
Old 11-11-2014, 07:35 AM   #1
86foxbody's Avatar
1995 5.0 need help
my dad recently bought a 1995 5.0 but when you turn it on it revs up really high idk what the problem is, does anyone know why it revs up really high when you start it
86foxbody is offline   Reply With Quote
Old 11-11-2014, 08:08 AM   #2
Shifty 5.0's Avatar
Clean the MAF sensor with MAF cleaner and also clean the IAC sensor (idle air control)
Shifty 5.0 is offline   Reply With Quote
Old 11-11-2014, 09:34 AM   #3
kyle_rivas's Avatar
Also get a tune up new wires spark plugs new oil and all that if not already done and could it possibly be bad timing?
instagram @5.0_rivas
kyle_rivas is offline   Reply With Quote
Old 11-11-2014, 11:31 AM   #4
86foxbody's Avatar
ok what if i clean all that is there anything else that could be the problem?
Old 11-11-2014, 01:32 PM   #5
smurf stang's Avatar
If this is a new purchase then a full tune up is in order.
Plugs, wires, cap, rotor, fuel filter, oil change, clean the maf, base idle reset, clean the iac, pcv valve and metal screen, run your codes, check and clean the grounds. Spend a day going through her and admiring her from all angles.
After you do all that then it will be easier to track down the culprit. It could be a vacuum leak.
2016 VW GTI 2.0 Turbo
Old 11-12-2014, 12:23 PM   #6
Hellish Horse's Avatar
I think you were right the 1st time Smurf...The MAF & IAC Sensors need cleaned.
I can't believe how much of a big deal those 2 sensors are....but they are !!!
Hellish Horse is offline   Reply With Quote
Old 11-12-2014, 04:46 PM   #7
True so very true. It's like a team sport.
Old 11-26-2014, 10:58 PM   #8
steveo201193's Avatar
I would say there could also be an intake leak somewhere. If the above doesn't fix anything you might look into that.
steveo201193 is offline   Reply With Quote
Help Help Help....1995 mustang 3.8 Princehollie Pre-2005 V6 Mustang 4 07-03-2014 07:42 PM
1995 Mustang Cobra :: 1995 Ford Mustang Cobra jwhayne0001 Member Garages 0 08-21-2011 12:22 AM
1995 Mustang, need help! ): austinray4142 Pre-2005 V6 Mustang 22 07-28-2011 11:28 AM
1995 Mustang GT :: 1995 Ford Mustang Ripastanky Member Garages 0 06-15-2011 01:01 PM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 07:56 PM
02:45 PM
