Cam? - Mustang Evolution
Old 11-14-2014, 08:32 PM   #1
kyle_rivas's Avatar
Cam?
What is the best cam for a stock 1995 5.0
instagram @5.0_rivas
kyle_rivas is offline   Reply With Quote
Old 11-14-2014, 08:37 PM   #2
Shifty 5.0's Avatar
Probably the B-cam but it's going to be just for sound on stock heads.
Shifty 5.0 is offline   Reply With Quote
Old 11-15-2014, 05:51 PM   #3
86foxbody's Avatar
What about the e303 cam?
86foxbody is offline   Reply With Quote
Old 11-15-2014, 06:38 PM   #4
Shifty 5.0's Avatar
That's a good cam too but unless you have 1.7 rockers to create a bigger lift the Ecam in a stock motor will have a slight lope to it compared to a lot of other cams
Old 11-15-2014, 07:22 PM   #5
Comp cams makes a nice stock upgrade and i agree with the b cam but since you have an auto with no stall the e cam will suit your car better
Bigshow14 is offline   Reply With Quote
Old 11-18-2014, 10:59 PM   #6
smurf stang's Avatar
Stock car......stock cam. The heads and intake are way bigger restrictions than the stock cam plus it's a big job just to swap a cam.
The Bathroom
2016 VW GTI 2.0 Turbo
Old 11-23-2014, 08:41 AM   #7
silverstone's Avatar
What is a good head to run with the comp cam extreme270. Got told it was a great cam. Thinking about doing it with some new heads too. What would be the best combination for that cam? Any ideas. Thanks.
silverstone is offline   Reply With Quote
Old 11-23-2014, 08:42 AM   #8
Shifty 5.0's Avatar
Edelbrock street heads or trickflow.
Old 11-23-2014, 08:50 AM   #9
Why not gt40x306?
Old 11-23-2014, 09:03 AM   #10
Shifty 5.0's Avatar
Why not gt40x306?
AFR and TRICKFLOW will give you more airflow. Everyone runs trickflow because running those heads with one of their cams or a pretty big cam with their intakes and a tune you get a pretty big jump in power also the main reason I got them is because down the road you can use them on a bigger motor and the trickflow heads you can massively port for a bigger motor where as the GT40x heads and AFR you won't be able to port as much. AFR is extremely good also but there's a reason you see trickflow heads everywhere.
Old 11-23-2014, 09:11 AM   #11
Would you have a part number for those heads? I'll check them out later when I have time. Thanks.
Old 11-23-2014, 09:29 AM   #12
Shifty 5.0's Avatar
Item #TFS-51400004M61
Old 11-24-2014, 05:53 AM   #13
Stock block should= cheapest HCI you can do such as a JY iron GT40 or just freshen the stock heads. Cheap used TFS1 cam (or just leave the stocker in), fuel system, suspension and a supercharger.
You'll spend less supercharging than you will doing a HCI, make more power, retain stock street manners, get 20+mpg on the highway etc...
Been there, done that, if I ever get another 5.0 pushrod it will be another 94/95 Cobra and it will get the basic bolt on treatment and then a S trim turned to 450whp. There is 0 way in hell I'd ever do another HCI again.
Old 11-24-2014, 06:07 AM   #14
450hp is my goal. Will the vorteck si get my there on stock heads and cam?
Old 11-24-2014, 06:51 AM   #15
To the flywheel it will be close. To the wheels you are going to be limited to about 400 with a safe boost number from the Vortech. I mean you should be doing springs and a valvejob to old stock E7 heads anyway so I'd suggest trying to find a set of non "P" GT40s from the junkyard and getting them cleaned up and install those. That'll drop another 40whp by itself over the stockers even in NA form.
Old 11-24-2014, 09:00 AM   #16
With the TFS1 cam added to the mix, will that give me the extra 50hp?
Old 11-24-2014, 01:56 PM   #17
Not with stock heads no. The heads and intake are the bottleneck on the pushrod 5.0 motor. The stock cam is actually pretty good.
Old 11-24-2014, 01:59 PM   #18
Good to know thanks.
Old 11-26-2014, 09:54 PM   #19
steveo201193's Avatar
I run trick flow heads with an x303 on my 90' and love it
steveo201193 is offline   Reply With Quote
Well the RPM heads and cam are installed!!!! Danger Dude Pre-2005 V6 Mustang 4 10-14-2008 06:53 AM
3.8 V6 Comp Cam Performance Cam nmaraijko Mustang Parts for Sale and Wanted 0 11-15-2006 07:11 AM
Cam Cores needed for RDMotorsport cam GP RGR Mustang Parts for Sale and Wanted 3 03-05-2005 05:53 AM
Cam Install ? dapack69 Pre-2005 V6 Mustang 6 09-04-2003 01:40 AM
10:11 PM
