Ford 302 roller rockers question. - Mustang Evolution
Old 11-16-2014, 06:43 PM   #1
Haav2's Avatar
I was given a brand new set of scorpion roller rockers that say 1.6 and 3/8 on them. Box comes with 16 of them and some other things that would come normally come with this set. I'm wondering if I can install these replacing the old ones or do I have to replace other parts in the valvetrain in order to use these.
Haav2 is offline   Reply With Quote
Old 11-16-2014, 07:09 PM   #2
I believe that the 3/8 are stud mount so you'll have to install 3/8 studs and possibly guide plates for the pushrods
Did the rockers come with any instructions?
What does the set include?
Old 11-16-2014, 07:12 PM   #3
Haav2's Avatar
It came with this right here.
Old 11-16-2014, 07:15 PM   #4
Haav2's Avatar
I don't really know what those black things are but that's all that the box came with, exactly what's on the pic. A friend gave me this set for free so I'm just trying to see if I'm gonna need other parts.
Old 11-16-2014, 07:18 PM   #5
Check the part# to be sure that they are stud mount rockers and if they are, you will need the studs and guide plates to install them.
Old 11-16-2014, 07:20 PM   #6
The black thing is the nut used to adjust them and lock them into place.
Old 11-16-2014, 07:23 PM   #7
Haav2's Avatar
Part number is: scp1017bl
Old 11-16-2014, 07:24 PM   #8
Haav2's Avatar
Yeah they're stud mounted. So you're saying I'm gonna need a set of 3/8 studs? What else do I need?
Old 11-16-2014, 07:32 PM   #9
Yes they are.
Typically, you need guide plates for the pushrods as well.
The studs and plates are very easy to install.
All of the rest of the valve train components will work with the rocker arms.
That was very nice of your friend to give those to you. Those are good ones!
Old 11-16-2014, 08:29 PM   #10
Haav2's Avatar
Thanks. We're building forged internal supercharged set up with hci. Friend said might as well throw in these rockers I've never had a chance to use.
Old 11-20-2014, 05:01 PM   #11
Hellish Horse's Avatar
Not sure how you can install Stud Mount Rockers on Pedestal Mount Heads when Stud mounts are 3/8" & Pedestal Mount are 5/16". I was told I had to have pedestal mount so that's what I bought. Good Luck installing those.
Hellish Horse is offline   Reply With Quote
Old 11-20-2014, 05:09 PM   #12
Haav2's Avatar
I ended up selling the set, I noticed some rockers where chipped at the bottom.
Old 11-20-2014, 05:31 PM   #13
Haav2's Avatar
I'm gonna get the right set that I need when I'm ready.
Old 11-20-2014, 05:35 PM   #14
Crane cams makes a conversion kit.
http://www.latemodelrestoration.com/...Arm-Conversion
Sent from my SAMSUNG-SGH-I747 using Mustang Evolution mobile app
Old 11-20-2014, 06:10 PM   #15
I've heard a lot of people say Pro Comp Roller Rockers are crap. I have no idea why as I've used them for over a year now & I know 2 other guys who also use them & none of us have had any issue with them. They're only $170 from Summit.
Anyway, you'll probably want to stay with 1.6 R.R.'s as you'll need taller valve covers if you use 1.7's.
Old 11-20-2014, 09:09 PM   #16
I've had a set of cast aluminum, stud mount, Comp cams roller rockers on my 460 for 410k miles. The pushrod guide inserts weren't changed until 380k miles... And not a moment too soon!
The Comp cams High Energy are probably in the same quality range as Pro Comp but, for most street engines, they should be pretty bulletproof. Hell, I've seen expensive billet aluminum rockers break when run at high RPM's for sustained amounts of time.
The main advantage to using stud mounted rockers is that they are infinitely adjustable without having to monkey around with different push rod lengths and shims. My 460 had so much material removed from the cylinder head and the block deck that installing the stud mounted rockers was easier for me than figuring out the pushrod lengths.
roller rockers bigpomps Pre-2005 V6 Mustang 8 07-05-2005 07:36 PM
WTB 1.8 Roller Rockers Cougarstang Mustang Parts for Sale and Wanted 0 08-18-2004 10:39 PM
1.8 Ratio Roller Rockers 6OnFire Pre-2005 V6 Mustang 9 02-07-2004 09:59 AM
12:06 AM
